[GeoNetwork-devel] Build Geonetwork with Eclipse :
Hello,
I try to build the CVS Head of Geonetwork with eclipse :
Buildfile: /home/fbachraty/workspace/geonetwork/build.xml
compile:
   [delete] Deleting:
/home/fbachraty/workspace/geonetwork/web/WEB-INF/lib/geonetwork.jar
   [delete] Deleting:
/home/fbachraty/workspace/geonetwork/web/WEB-INF/lib/setup.jar
   [delete] Deleting:
/home/fbachraty/workspace/geonetwork/migrate/lib/migration.jar
   [delete] Deleting:
/home/fbachraty/workspace/geonetwork/csw/lib/csw-client.jar
   [delete] Deleting:
/home/fbachraty/workspace/geonetwork/csw/lib/csw-common.jar
    [mkdir] Created dir: /home/fbachraty/workspace/geonetwork/.build
    [javac] Compiling 178 source files to
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] Note: Some input files use unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
     [copy] Copying 1 file to /home/fbachraty/workspace/geonetwork/.build
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
   [delete] Deleting directory /home/fbachraty/workspace/geonetwork/.build
BUILD SUCCESSFUL
Total time: 4 seconds
It look good but when i replace the Geonetwork.jar (the 2.1 by the Head
built ) and restart my tomcat it don't work !
Looking at the geonetwork.jar i see that the original is nearly 670ko and
mine built is 380ko ?!
Any ideas ?
Thank you by advance
Cordialy Fabien Bachraty
INRA Avignon
View this message in context: http://www.nabble.com/Build-Geonetwork-with-Eclipse-%3A-tf4711877s18419.html#a13468219
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hello, try instead of /home/fbachraty/workspace/geonetwork/build.xml
/home/fbachraty/workspace/geonetwork/installer/build.xml.
This will create the installer and rebuild everything for version 2.1 in the
directory /home/fbachraty/workspace/geonetwork/geonetwork-2.1.0.
Then run the installer.
HTH. Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de
FBachraty
Envoyé : lundi 29 octobre 2007 15:15
À : geonetwork-devel@lists.sourceforge.net
Objet : [GeoNetwork-devel] Build Geonetwork with Eclipse :
Hello,
compile:
   [delete] Deleting:
   [delete] Deleting:
   [delete] Deleting:
   [delete] Deleting:
   [delete] Deleting:
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
      [jar] Building jar:
BUILD SUCCESSFUL
Any ideas ?
INRA Avignon
#a13468219
GeoNetwork-devel mailing list
Thank you for your help.
I do what you say, and i install it in a new folder as for the final 2.1
release i already have.
I configure Geonetwork config file, tomcat server.xml and policy.
But it display an error like that !
StandardContext[/geonetworkeclipse]La servlet /geonetworkeclipse a généré
une exception "load()"
javax.servlet.ServletException: Provider
org.apache.xalan.processor.TransformerFactoryImpl not found
----- Root Cause -----
javax.xml.transform.TransformerFactoryConfigurationError: Provider
Moreover the version compiled is the Head but it is not the final 2.1.
It's is the 2.1.0 alpha, i wish i could work on the final release with
geoserver and intermap embeded.
Is it possible ?
Thank you.
Fabien Bachraty
the
HTH. Francois
View this message in context: http://www.nabble.com/Build-Geonetwork-with-Eclipse-%3A-tf4711877s18419.html#a13485001
