[GeoNetwork-devel] build of GN2.1 beta
Dear GN developers,
I am wondering if there is a build available of GN 2.1 beta because I have some trouble compiling it. But I am not used to build jar files thus it is very likely that I am just doing something wrong.
This is the error message I get when I run ant -f build.xml:
[javac] org\fao\gast\Gast.java added as org/fao/gast/Gast.class doesn't exist.
[javac] org\fao\gast\app\App.java added as org/fao/gast/app/App.class doesn't exist.
[javac] org\fao\gast\app\Configuration.java added as org/fao/gast/app/Configuration.class doesn't exist.
Thanks in advance
Best regards
Paul
Paul HASENOHR
Community Image Data portal project
European Commission - Joint Research Centre
IPSC - Agriculture and Fisheries Unit
TP 266, 21020 ISPRA (VA), ITALY
Tel: +39 0332 78 60 93 - Fax: +39 0332 78 63 69
Web site: http://agrifish.jrc.it
Hi Paul,
maybe you made a checkout when I was committing some code.
Try an update 'svn up', go inside 'trunk' folder and issue 'ant'.
We should release the beta soon.
Dear GN developers,
exist.
doesn't exist.
Thanks in advance
Best regards
Paul
