[GeoNetwork-devel] Building from SVN: Trouble running
Hi GN Developers,
[Apologies if you've received this already, but I previously posted this to the GN users-list by mistake]
I've just compiled GeoNetwork from SVN (which I'm hoping is v2.3 with ISO 19119 support) and replaced the old "web" directory with the new one. However, I immediately see two problems (which may be related):
1) I get the following error when importing sample data with ther GAST:
type Status Report
message /geonetwork/srv/en/mef.import
description The requested resource (/geonetwork/srv/en/mef.import) is not available.
This would imply that it's looking for a "srv" subdirectory of "geonetwork", but there isn't one. Does this mean I need to install more than just the new web directory?
2) When I go to the Administraton->New Metadata page, there are no templates in the drop-down menu. Does anyone know why this might be? Might it be looking for the same "srv" directory?
If anyone has any experience installing version 2.3, then I'd be keen to hear if you had similar problems.
Many thanks,
Andy
