[GeoNetwork-devel] Building GN & skipping tests
Hi list,
is -DskipTests still required to build geonetwork, or is it a local error of
mine?
In the first case, wouldn't it be nicer to add @Ignore where needed, in order
to help whoever wishes to help fixing?
   Emanuele
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hi Emanuele,
2015-09-07 20:21 GMT+02:00 Emanuele Tajariol <etj@anonymised.com>:
Hi list,
mine?
In the first case, wouldn’t it be nicer to add @Ignore where needed, in order
+1.
Francois
Emanuele
Technical Lead
GeoNetwork-devel mailing list
On Tue, Sep 8, 2015 at 7:28 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
Hi Emanuele,
Hi list,
of
mine?
order
+1.
+1 Or even better: fix the tests that are failing right now so we can run
the full build without problems.
One of the main problems I see right now is that the build is sooo slow
that nobody enables the tests unless it is very obvious that the change you
have made needs an update on the tests. Am I right here?
Francois
   Emanuele
Technical Lead
I guess that a good starting point would be to allow the working tests to be
run.
I created an issue for topic:
   https://github.com/geonetwork/core-geonetwork/issues/1176
It also includes the temporary removal of the findbugs plugin: tests are not
working, adding one more layer of code checking seems overkill to me.
I have a commit ready to be pushed if you agree.
I'd like to add these changes to the 3.0.x stable branch, in order to make it
a bit more stable :).
   Emanuele
wrote:
> Hi Emanuele,
>> Hi list,
>> error of
>> mine?
>> order
> +1.
> Francois
>> Thanks,
>> Emanuele
Technical Lead
Hi devs,
you may have seen the users mailing list, where it has been noticed that the
travis build is failing since long.
Since the PR related to
also solves this problem, I would merge it if you agree (there have been +1
only on the idea, but not on the PR yet :slight_smile: )
   Emanuele
Alle 17:20:24 di Tuesday 8 September 2015, Emanuele Tajariol ha scritto:
be run.
not working, adding one more layer of code checking seems overkill to me.
it a bit more stable :).
   Emanuele
> wrote:
> > Hi Emanuele,
> >> Hi list,
> >> error of
> >> mine?
> >> in order
> > +1.
> you have made needs an update on the tests. Am I right here?
> > Francois
> >> Thanks,
> >> Emanuele
Technical Lead
Hi Emanuele
+1 for me also, please merge it.
Jose García
On Thu, Sep 24, 2015 at 10:44 AM, Emanuele Tajariol <etj@anonymised.com> wrote:
Hi devs,
Emanuele
be run.
I’d like to add these changes to the 3.0.x stable branch, in order to make
Emanuele
wrote:
Hi Emanuele,
Hi list,
error of
mine?
in order
+1.
Francois
Emanuele
Technical Lead
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
M: +31 (0)655 818332
Please consider the environment before printing this email.
+1 as well
On Thu, Sep 24, 2015 at 10:46 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Emanuele
Jose García
in one place.
Hi devs,
Emanuele
be run.
Emanuele
wrote:
Hi Emanuele,
Hi list,
error of
mine?
in order
+1.
Francois
Emanuele
Technical Lead
in one place.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Florent Gravin
0479444492
PR merged, travis back to green on 3.0.x.
I'll port the changes to the develop branch as well.
   Emanuele
Alle 10:48:52 di Thursday 24 September 2015, Florent Gravin ha scritto:
+1 as well
wrote:
> Hi Emanuele
> Regards,
> Jose García
> wrote:
>> Hi devs,
>> the
>> +1
>> Thanks,
>> Emanuele
>> > Hi,
>> > > can
>> run
>> to
>> > be run.
>> > are not working, adding one more layer of code checking seems
>> > overkill to
>> me.
>> make
>> > Cheers,
>> > Emanuele
>> scritto:
>> > > wrote:
>> > > > Hi Emanuele,
>> > > >> Hi list,
>> > > >> local error of
>> > > >> mine?
>> needed,
>> > > >> in order
>> > > > +1.
>> > > can
>> run
>> slow
>> change
>> > > > Francois
>> > > >> Thanks,
>> > > >> Emanuele
>> Technical Lead
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> ------ Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
>> in one place.
>> _______________________________________________
> *Vriendelijke groeten / Kind regards,Jose García
> <http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT:
> +31 (0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31655818332>
> <https://www.facebook.com/geocatbv&gt; <https://twitter.com/geocat_bv&gt;
> <https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
> environment before printing this email.*
> in one place.
Technical Lead
