[GeoNetwork-devel] Building the guiwidgets interface
Hello,
I am fairly new to maven so forgive me if my question reflects this ...
I would like to test the new guiwidgets interface for GeoNetwork but am
having difficulties building the repository. What I have done so far is
checked out the guiwidgets repository from
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/guiwidgets/.
(This is on a machine with GeoNetwork 2.7 already installed.) Then I used
maven in this directory with the command: mvn clean install. After trying a
couple different versions of maven (I now am using 6.0.20) I got it to run
for a minute until it hit this error:
[ERROR] Failed to execute goal on project geonetwork-main: Could not resolve
dependencies for project
org.geonetwork-opensource:geonetwork-main:war:2.6.0-RC0: T
he following artifacts could not be resolved:
org.geonetwork-opensource:jeeves:j
ar:2.6.0-RC0, ...
I noticed the poms have a mix of GeoNetwork versions in them, some 2.6 and
some 2.7. Do these need to be altered? Please give me some guidance if you
can.
Byron
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Building-the-guiwidgets-interface-tp6714320p6714320.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hello Byron,
2011/8/23 ByronCinNZ <cochranes4@anonymised.com>:
Hello,
the new experimental interface has been added to trunk during Bolsena
codesprint as an alternative for the UI.
See [1] for more details and configure it in config-gui.xml. From
trunk, build the installer and start from here I think.
Cheers.
Francois
PS : I'll remove the sandbox which is out of date now.
[1] http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui
ar:2.6.0-RC0, ...
can.
Byron
Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
user administration capabilities and model configuration. Take
the hassle out of deploying and managing Subversion and the
tools developers use with it. http://p.sf.net/sfu/wandisco-d2d-2
GeoNetwork-devel mailing list
Thanks Francois. You are always a great help.
Byron
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Building-the-guiwidgets-interface-tp6714320p6726489.html
