[GeoNetwork-devel] Calling mef.import - Parameters?
Hello,
I have a process that I am developing which requires 'insert metadata from
file' functionality. The mef.import service looks perfect for my needs, but
I cannot get it to work for me. The documentation says all it needs is an
'mefFile' parameter, but I cannot get this to work. Looking at the code add
the request posted by mef.import.ui, I assume that this service is expecting
multipart parameters. If so, how do I supply these? What format should the
parameters be in?
Thanks in advance.
Byron
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Calling-mef-import-Parameters-tp6979446p6979446.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Byron,
I had the same problem before. If you are calling this service from a web
page, you can try with the following code added to the body of your HTML
page.
<form id='sampleform1' method='post'
  enctype="multipart/form-data"
  action='http://localhost:8080/geonetwork/srv/en/mef.import’>
   <p>
   File: <input type='file' name='mefFile' />
   </p>
   <p>
   <input type='submit' name='Submit' value='Send' />
   </p>
</form>
That is pretty much what you need to import a mef file via the web page.
I have got no clue if you are working with other implementations like
command line or java applet. Some one else might be able to help.
Cheers, Alex
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Calling-mef-import-Parameters-tp6979446p6995145.html
