Am 01/07/2015 um 22:01 schrieb Kai Liu:
I agree with you. The SOS should be separated with other OGC WxSs and it
needs the AcceptVersions parameter. But I am wondering if all the SOS
servers use AcceptVersions? or only the specific versions of 52N use
this parameter?
The SOS server supports AcceptVersions, but not "versions", which is not a specified query parameter for GetCapabilities.
The difference to the newer 52N SOS versions is that it will return an exception if the invalid parameter is provided. Older versions simply ignored it.
Hope this clarifies,
Daniel
On Wed, Jul 1, 2015 at 7:13 AM, Daniel Nüst <d.nuest@anonymised.com
<mailto:d.nuest@anonymised.com>> wrote:
Am 21/10/2013 um 21:21 schrieb kliu4:
> When I harvest the SOS (
http://kiwis.kisters.de/KiWIS/KiWIS?datasource=3&request=GetCapabilities&service=SOS&version=2.0.0
> ) using GeoNetwork 2.10.10, It has some problem ton convert SOS
to ISO
> 19139 as below. I am wondering if the problem can be fixed by
modifying
> the OGCSOSGetCapabilitiesLayer-to-19139.xsl
> 2013-10-21 12:30:44,359 WARN [geonetwork.harvester] - Raised
exception
> while ha
> rvesting from : kiwis (OgcWxSHarvester)
> 2013-10-21 12:30:44,359 WARN [geonetwork.harvester] - (C) Class :
> IllegalSta
> teException
> 2013-10-21 12:30:44,360 WARN [geonetwork.harvester] - (C) Message :
> Root eleme
> nt not set
> java.lang.IllegalStateException: Root element not set
> at org.jdom.Document.getRootElement(Document.java:218)
> at jeeves.utils.Xml.transform(Xml.java:401)
> at
> org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester.addMetadata(
> Harvester.java:284)
> at
> org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester.harvest(Harv
> ester.java:233)
> at
> org.fao.geonet.kernel.harvest.harvester.ogcwxs.OgcWxSHarvester.doHarv
> est(OgcWxSHarvester.java:227)
> at
> org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWith
> IndexProcessor.process(AbstractHarvester.java:400)
> at
> org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(Abs
> tractHarvester.java:470)
> at
> org.fao.geonet.kernel.harvest.harvester.HarvesterJob.execute(Harveste
> rJob.java:29)
> at org.quartz.core.JobRunShell.run(JobRunShell.java:213)
> at
> org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.j
> ava:557)
A post elaborating more on this problem has not been published yet to
the mailing list but is available in the nabble forum:
http://osgeo-org.1560.x6.nabble.com/Can-not-convert-SOS-to-ISO-19139-tp5084930p5201033.html
Extending on that post, we have taken a look at the server logs during
the harvesting and have found the following: The (new version of the
52N) SOS (4.x) gives an error when the "version" request parameter is
present:
Request gives exception:
.../sos?service=SOS&REQUEST=GetCapabilities&Version=1.0.0
Request works:
.../sos?request=GetCapabilities&service=SOS&AcceptVersions=1.0.0
The request parameter could be safely ignored by the server side, so
that would be one way of fixing it.
However, since the GetCapabilities operation does not have a version
parameter (it does not make send, because I execute GetCapabilities
precisely to get to know the available versions), do you agree that is a
bug in the Harvester?
The line is
https://github.com/geonetwork/core-geonetwork/blob/develop/harvesters/src/main/java/org/fao/geonet/kernel/harvest/harvester/ogcwxs/Harvester.java#L206
This should use the ACCEPTVERSIONS parameter.
Thanks for your help!
/Daniel
Daniel Nüst
52°North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster, Germany
E-Mail: d.nuest@anonymised.com <mailto:d.nuest@anonymised.com>
Fon: +49-(0)-251–396371-36 <tel:%2B49-%280%29-251%E2%80%93396371-36>
Fax: +49-(0)-251–396371-11 <tel:%2B49-%280%29-251%E2%80%93396371-11>
http://52north.org/
Twitter: @FiveTwoN
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-devel mailing list
<mailto:GeoNetwork-devel@lists.sourceforge.net>
Kai Liu
Ph.D. student
Department of Geography and GeoInformation Science
George Mason University
Daniel Nüst
http://52north.org/
Twitter: @FiveTwoN
