Hi All,
I have had a modified BlueNet MEST (GN Version 2.2.0) configured and setup on our server. I have tried to login as administrator to GN using the Username and Password interface. I keep getting the following error:
Login Error
The username or the password is wrong.Press the 'back' button and try again.
UserLoginEx : User login failed
Back to previous page
I don't want to re-install GN because it will probably override all the customisation that was done on GN. The setup has been checked into Subversion.
I believe it has been configured with Tomcat and McKoi.
Is there anyway of finding out via the configuration files if the username and password has been switched off?
Is there anyway of changing the administrator's username and password via the configuration files? If so what configuration files do I look in?
Thanks.
John Hockaday
Geoscience Australia
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
http://www.ga.gov.au/
john.hockaday\@ga.gov.au
