I have been working with Bob on this issue and it is still NOT resolved. I
have been trying to dig into this deeper and am wondering if the app needs
to reference the JNDI tree in order to instantiate the Context which
apparently is null? If so, is there any properties that I need to change to
point the app to Websphere's JNDI tree instead of its default since I have
the app deployed on a Websphere server? Perhaps I need to update the
jndi.properties file? Or if I am off base are there any other suggestions
as to where I can look? We appreciate the help so far. Thanks.
hi,
I took a quick look and it appears the errors you're getting indicate that
your GeonetContext is null; it's usually accessed like this
GeonetContext gc = (GeonetContext)
context.getHandlerContext(Geonet.CONTEXT_NAME);
but subsequent references to "gc" throw the NullPointerExceptions.
This being so, I have no idea why this is happening. I guess it has to do
with exactly how you deployed the application to WebSphere; how did you do
it? As the standard GeoNetwork build script does not produce a standard
deployable artefact such as an EAR or WAR file.
Recently someone created a build process that outputs a WAR, maybe you have
better results with that; see the "sandbox/geonetworkui/BlueNetMEST/" source
tree in SVN to find it ..
kind regards
heikki doeleman
On Tue, Jul 1, 2008 at 7:05 AM, Bob Nutsch <bnutsch@anonymised.com> wrote:
Hi Jeroen,
We have the log now, thanks, and have attached it to this post. If you
could have a look to get an idea of what might be happening, I'd sure
appreciate it.
Thanks, Bob
http://www.nabble.com/file/p18214986/geonetwork.log geonetwork.log
Jeroen Ticheler-3 wrote:
> Hi Bob,
> Logging is done by log4j. the log4j.cfg file defines where logging is
> written. Using Jetty this would be in the jetty/log folder. Using
> another servlet engine, this location may be different due to the
> relative path configured in the log4g.cfg configuration (located in
> web/geonetwork/WEB-INF). You could hardcode the location used to log.
> It defaults to:
> log4j.appender.jeeves.file = log/geonetwork.log
> Ciao,
> Jeroen
> On Jun 26, 2008, at 8:24 PM, Bob Nutsch wrote:
>> Hi Jeroen,
>> We set up the Oracle database with GAST. We can see the demo data
>> in those
>> tables, and we can see the admin/admin info.
>> We are wondering what logs we should be looking for and where they
>> exist.
>> We don't have anything showing up on the console. Where is logging
>> switched
>> on?
>> Regards, Bob
>>> Hi Bruce,
>>> Hard to say what's happening... The user details are stored in the
>>> database. How did you set up the Oracle database? Do you have more
>>> detailed log output for me?
>>> Ciao,
>>> Jeroen
>>> On Jun 24, 2008, at 4:38 PM, Bob Nutsch wrote:
>>>> Hi Jeroen,
>>>> When running on a default install of GeoNetwork (using Jetty,McKoi)
>>>> I can
>>>> log in as admin/admin, change the password, and noted that the
>>>> config.xml
>>>> was untouched, but one of the files in the McKoi directory was
>>>> touched.
>>>> When I try to log in with a bad password, I get a message stating,
>>>> "The
>>>> username or password is wrong..." which I would expect. But on our
>>>> WebSphere installation, we simply get the nullpointexception which
>>>> suggests
>>>> to us there is a basic problem with the system finding what it
>>>> needs. Is the
>>>> admin/admin userid and password stored in the application, the DB or
>>>> somewhere else? Since we get the null pointer exception regardless
>>>> of what
>>>> we enter for a userid and password it would seem that there is a
>>>> piece
>>>> missing in our application. Is there some security setup that we
>>>> are
>>>> missing?
>>>> Thanks, Bob
>>>>> Hi Bob,
>>>>> Normally this should be admin/admin and not your db username and
>>>>> password since that one is not related to the user account for the
>>>>> application. If you can't resolve this, you may need to manually
>>>>> edit
>>>>> the password in Oracle...
>>>>> Ciao,
>>>>> Jeroen
>>>>> On Jun 23, 2008, at 10:32 PM, Bob Nutsch wrote:
>>>>>> Hello Heikki,
>>>>>> Thanks for the input. We do have regions appearing in the
>>>>>> dropdown
>>>>>> list.
>>>>>> We changed the name of a region in oracle and that change came
>>>>>> through in
>>>>>> the dropdown list.
>>>>>> We are wondering if we should be logging in as admin/admin or
>>>>>> using
>>>>>> the
>>>>>> Oracle userid/password? We've tried both approaches and get the
>>>>>> same
>>>>>> results.
>>>>>> Thanks, Bob
>>>>>> heikki doeleman wrote:
>>>>>>> hi,
>>>>>>> this really sounds like you don't have a properly working
>>>>>>> connection to
>>>>>>> your
>>>>>>> database. To check that, do you see a list of regions in the
>>>>>>> regions
>>>>>>> dropdownlist, near the minimap ? (you'll only have them if your
>>>>>>> database
>>>>>>> connection is working properly).
>>>>>>> regards
>>>>>>> heikki
>>>>>>> On Mon, Jun 23, 2008 at 9:41 PM, Bob Nutsch <bnutsch@anonymised.com>
>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> We have deployed GeoNetwork to WebSphere 6.1 on a development
>>>>>>>> PC.
>>>>>>>> We can
>>>>>>>> fire up GeoNetwork but it's not completely working.
>>>>>>>> The main page comes up and everything displays correctly however
>>>>>>>> when I
>>>>>>>> try
>>>>>>>> to login as the admin using admin/admin or any other userid and
>>>>>>>> password,
>>>>>>>> an
>>>>>>>> error is displayed reading "The requested operation could not be
>>>>>>>> performed".
>>>>>>>> Right below the error message "NullPointerException:" is
>>>>>>>> displayed.
>>>>>>>> I am using Oracle for my database and updated the config.xml to
>>>>>>>> the
>>>>>>>> following:
>>>>>>>> <resource enabled="true">
>>>>>>>> <name>main-db</name>
>>>>>>>> <provider>jeeves.resources.dbms.DbmsPool</provider>
>>>>>>>> <config>
>>>>>>>> <user>myDBUserid</user>
>>>>>>>> <password>myDBPassword</
>>>>>>>> password>
>>>>>>>> <driver>oracle.jdbc.driver.OracleDriver</driver>
>>>>>>>> <url>jdbc:oracle:thin:@myDBServer
>>>>>>>> :2901:cdd4</url>
>>>>>>>> <poolSize>10</poolSize>
>>>>>>>> </config>
>>>>>>>> </resource>
>>>>>>>> Any help greatly appreciated.
>>>>>>>> Thanks, Bob
View this message in context: http://www.nabble.com/Cannot-log-in%2C-NullPointerException-tp18076751p18635297.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
