[GeoNetwork-devel] Can't build a valid war archive from sources
Hello everyone,
I'm trying to compile geonetwork from sources and deploy it on tomcat7 app
server. I used the sources from a stable develop branch and did it step by
step as in manual on geonetwork website. I got all succes messages in maven
prompt, but the war file is not correct. I can't run the file on my tomcat
serwer. Previously, I downloaded a war file from Sourceforge website and it
was working perfecty. There is no index html file in a war created from
sources and h2 databasees wre created (with errors) in main directory (not
in webapps folder!). I also tried to compile latest release version
(2.10.3), but I got an error:
[ERROR] Failed to execute goal on project cachingxslt: Could not resolve
dependencies for project org.geonetwork-opensource:cachingxslt:jar:2.10.3-0:
Failure to find net.sf.saxon:saxon:jar:9.1.0.8b-patch in
http://download.osgeo.org/webdav/geotools/ was cached in the local
repository, resolution will not be reattempted until the update interval of
geotools has elapsed or updates are forced -> [Help 1]
[ERROR]
Can anyone help me to build a valid war archive from sources? Thank you in
advance.
Best regards,
Marek
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-build-a-valid-war-archive-from-sources-tp5169905.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
2014-10-28 12:26 GMT+01:00 silo <mmarczak@anonymised.com>:
Hello everyone,
I’m trying to compile geonetwork from sources and deploy it on tomcat7 app
prompt, but the war file is not correct. I can’t run the file on my tomcat
sources
/home is the home page and takes care of redirection depending on browser language, …
https://github.com/geonetwork/core-geonetwork/blob/stable-develop/web/src/main/webResources/WEB-INF/web.xml#L370
It’s normal to not have index.html file.
h2 db by default is configured with relative path (https://github.com/geonetwork/core-geonetwork/blob/stable-develop/web/src/main/webapp/WEB-INF/config-db/h2.xml#L18). Use full path if you want the db to be in a specific location /app/geonetwork-db for example.
What type of errors do you have when the app starts ?
If you run
cd web
mvn jetty:run
does it work ok ?
Francois
geotools has elapsed or updates are forced → [Help 1]
[ERROR]
advance.
Best regards,
Marek
GeoNetwork-devel mailing list
2014-10-29 9:09 GMT+01:00 Marek Marczak <mmarczak@anonymised.com>:
OK, I fixed it.
Ok good.
It turns out that java on linux is more memory restricted. I needed to
enlarge default java memory in JAVA_OPTS system variable and also set
bigger PermGen size. I noticed that lastest stable development version has
bigger memory requirements than lastest release version (2.10.3).
Yes you have to set JAVA_OPTS to avoid OutOfMemory error. Like for the
build, you need to set MAVEN_OPTS.
If set you'll have:
[INFO] --- gmaven-plugin:1.0:execute (Check memory settings) @ geoserver ---
[INFO]
Max Heap Memory: 1024.0 MB
Max PermGen Size: 256.0 MB
If not
[INFO] --- gmaven-plugin:1.0:execute (Check memory settings) @ geonetwork
[INFO]
Max Heap Memory: -1 MB
Max PermGen Size: -1 MB
[ERROR]
In order for the build to complete both the -Xmx parameter and the
-XX:MaxPermSize= must be set. The e2e tests require this because the start
Geonetwork and run tests against it which takes a lot of memory.
Cmd/Powershell:
$Env:MAVEN_OPTS="-Xmx512M -XX:MaxPermSize=256M"
Bash/SH:
export MAVEN_OPTS="-Xmx512M -XX:MaxPermSize=256M"
develop/stable-develop branch require a bit more memory on startup than
2.10 mainly due to the on-the-fly build/minification of JS and Less files
(related to Wro4j module).
Francois
Best regards,
Marek
W dniu 2014-10-28 o 13:24, Francois Prunayre pisze:
Hello everyone,
app
maven
it
sources
browser language, ...
It's normal to not have index.html file.
If you run
cd web
mvn jetty:run
does it work ok ?
Francois
of
[ERROR]
advance.
Best regards,
Marek
Marek Marczak+48 17 864 24 82
OPGK RZESZÓW S.A.
Rzeszów ul. Geodetów 1, 35-328 Rzeszów
tel. sekr. +48178624816,
tel. centr. +48178642400,
fax +48178621414
