I tried this, but it turns out that it has already happened by this stage.
So while this code works, it is not where my problem is. I cant see
anywhere in the HTML that might do this. It happens in Firefox, IE and
Opera, so it is not the browser. The only area I know of that might do it,
although I cant see any reason for it to affect it in this way, is the
EditLib code that adds the geonet elements.
The way I work, which is for adding a new format, is to alter my XSL
templates and then make Geonetwork update the edit page by switching between
Simple View and XML View. It seems that the double newline issue is
occurring when I go from Simple to XML View. The extra newlines are already
in the XML View when I get there. Then, when I switch back to Simple View to
see my XSL changes, it presents the extra newlines as they were in XML View.
So from this, I dont think it is in the XSL templates, or if it is, it is
in the XML View portion of them.
Just to clarify this, if I add a new line (and text after it) to a textarea
while in XML View, and then switch to Simple View, I do NOT get the double
newline problem. But if I add the newline (ant text) while in Simple View,
and then switch to XML View, I DO get the double newline problem. So it
seems that it is in the preparation on the XML View page.
Steven Smith <steven.smith@anonymised.com>
Software Developer / Analyst
Geometry Pty Ltd
Telephone
03 6223 1999
Facsimile
03 6223 1988
Web
www.geometryit.com
<file:///C:\Documents%20and%20Settings\ssmith.GEOMETRY\Application%20Data\Mi
crosoft\Signatures\www.geometryit.com>
Address
31 Salamanca Square, Battery Point, TAS 7004, Australia
Postal
PO Box 844, Sandy Bay, TAS 7006, Australia
Building Intelligent Business through the Power of Spatial
_____
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] On Behalf Of Angel
Zaballos
Sent: Friday, 17 November 2006 7:18 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Carraige returns being doubled
Hi Steven,
Ive reported the same bug one month ago. Youll find the answer by François
Prunayre in the geonetwork developer mailing list with extra new lines in
textarea fields subject. François proposed the next quick workaround:
Line 667 in metadata.xsl
Replace <xsl:value-of select="text()"/>
<xsl:call-template name="preformattedEdit">
<xsl:with-param name="text" select="text()"/>
</xsl:call-template>
And add this template to metadata.xsl
<xsl:template name="preformattedEdit">
<xsl:param name="text"/>
<xsl:choose>
<xsl:when test="contains($text,' ')">
<xsl:value-of select="substring-before($text,' ')"/>
<xsl:text> </xsl:text>
select="substring-after($text,' ')"/>
</xsl:when>
<xsl:otherwise>
<xsl:value-of select="$text"/>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
And it works very fine!
Best Regards,
Angel Zaballos
Angel Zaballos
Software Engineer
GTD SISTEMAS DE INFORMACIÓN
Pg. Garcia Fària, 17
E-08005 Barcelona
www.gtd.es
Tel: +34 934 939 300
Fax: +34 932 255 080
angel.zaballos@anonymised.com
_____
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de Steven
Smith
Enviado el: viernes, 17 de noviembre de 2006 4:19
Para: geonetwork-devel@lists.sourceforge.net
Asunto: [GeoNetwork-devel] Carraige returns being doubled
I have found a bug in Geonetwork that causes carriage returns to
be doubled (every instance is doubled) in textareas each time I rebuild the
edit form. I cant find anywhere in the XSL that might do this so I was
hoping that someone might have some idea where this might be happening.
Thank you.
Geometry Pty Ltd
Telephone
03 6223 1999
Facsimile
03 6223 1988
Web
www.geometryit.com
Address
Postal
