[GeoNetwork-devel] CFV: Existing GUI as default and Widgets based GUI as experimental - is it possible to test?
Dear Jeroen,
I would like to ask you whether it is possible to deploy the current version of the GeoNetwork you are mentioning within your email in order to test the new GUI widgets?
Or is it enough to check out the current trunk version deploy it and just change some configurations?
Many thanks in advance for your advice,
Tomas
On 27 April 2012 09:52, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
Dear PSC and core developers,
I hereby propose to have the existing GUI to remain the default interface when installing GeoNetwork. The Widgets based GUI will be released as experimental GUI with the installer.
At GeoCat we think the new ExtJS widgets based GUI is not stable enough yet to become the default GUI. The ExtJS GUI will be an optional interface and there will be documentation on how to configure GeoNetwork to use the new GUI as default.
Thanks for your urgent voting. Cheers,
Jeroen
**GeoCat** introduces Bridge© An extension to ArcGIS© to instantly publish data and metadata on GeoServer and GeoNetwork. See [http://geocat.net](http://geocat.net/) for more details.
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31 (0)6 81286572
http://geocat.net
Please consider the environment before printing this email.
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Ing. Tomas Kliment
Contact information:
Private:
Juzna 4, 04801 Roznava, Slovakia
Tel: +421 907 232019
Tel: +39 389 4955 954
e-mail: tomas.kliment@anonymised.com
www: http://about.me/klimeto
Ph.D. student:
Slovak University of Technology
Faculty of Civil Engineering
Department of Theoretical Geodesy
Radlinskeho 11, block A, 5th floor
813 68 Bratislava 15, Slovakia
Tel: +421 259274 297
Ph.D. Internship - Junior Researcher:
The National Research Council
Institute of Marine Science, Venice, Italy
External consultant:
Polymedia S.p.A, KIT Digital Company
Joint Research Centre of European Commission, Ispra, Italy
Hi Tomas,
Through the geonetwork website you can find the nightly builds of trunk from the downloads page. That installer currently still has the (incomplete) GUI widgets interface configured as the default interface.
Kind regards,
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Send from mobile phone.
Op 30 apr. 2012 om 13:54 heeft Tomas Kliment <tomas.kliment@anonymised.com> het volgende geschreven:
Dear Jeroen,
Tomas
Jeroen
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://geocat.net
<GeoCat_small.png>Please consider the environment before printing this email.
Ing. Tomas Kliment
Private:
Ph.D. student:
