I have just finished the work on unified Javascript build/minification/testing and would like to merge the work on the mainline ASAP.
The proposal with details is on the wiki:
https://github.com/geonetwork/core-geonetwork/wiki/Wro4J-Integration
Jesse
I had tested the branch recently and it worked pretty well with a simple mvn command line.
It is essential for the build when we are introducing new components as angular, nodejs, less files, closure etc…
Thanks for this work.
+1
On Mon, Jan 6, 2014 at 11:02 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jesse
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Florent Gravin
Camptocamp - Chambéry
0479444492
Hi Jesse,
This looks like an excellent proposal with a lot of benefits to the project.
+1 from me to see this integrated ASAP.
Cheers and a Happy New Year,
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
_________________________Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
Op 6 jan. 2014 om 11:02 heeft Jesse Eichar <jesse.eichar@anonymised.com> het volgende geschreven:
Jesse
+1 for me Jesse.
I’ve tested it also and it works well. It will be really useful for end-user who would like to make minor changes in the JS config (eg. config map) and will not need the full source code to rebuild everything.
Once in develop branch, we’ll also test it more in depth with Florent after merge to the editor refactoring branch.
Cheers.
Francois
2014/1/6 Jesse Eichar <jesse.eichar@anonymised.com>
Jesse
+1
not tested yet, but looks like a useful improvement.
Ciao,
Emanuele
Alle 11:02:32 di Monday 6 January 2014, Jesse Eichar ha scritto:
ASAP.
Jesse
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
