[GeoNetwork-devel] CFV / Metadata editor
Dear PSC,
Here is the proposal for the new metadata editor based on AngularJS https://github.com/geonetwork/core-geonetwork/wiki/Refactoring-editor
It also includes the directory manager and some fixes & improvements in the administration UI.
Looking forward to your votes.
Thanks.
Florent & Francois
Dear François,
This is a really nice proposal and work. Definitely a +1 from me.
Jeroen
On 17 feb. 2014, at 09:56, Francois Prunayre <fx.prunayre@anonymised.com.31…> wrote:
Dear PSC,
Thanks.
Florent & Francois
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk_______________________________________________
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.come.net
An important proposal and it is coming along very nicely.
Jesse
On Mon, Feb 17, 2014 at 9:56 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Dear PSC,
Thanks.
Florent & Francois
Hi Francois
The proposal looks really good and also hope that makes easier the developments/customisations related to the metadata editor in GeoNetwork.
You have the +1 from me, but 2 things to clarify:
  • The new developments only supports IE from version 9. Users that have old versions of IE will be able to use the 2.10 widgets UI? Just to be sure there’s an alternative as in many organisations users can decide to upgrade the software easily or even use XP (even if unsupported :wink: that only allows until IE8.
  • How affects to the existing custom metadata profiles developed (like for example the profiles in https://github.com/geonetwork/schema-plugins)? Are required any changes? In that case, are there any guidelines for the migration?
Jose García
On Tue, Feb 18, 2014 at 1:42 PM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jesse
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Thanks.
Florent & Francois
Apologies, in my previous mail I did a typo, should be: as in many organisations, users can’t decide to upgrade the software easily
Jose García
On Thu, Feb 20, 2014 at 4:15 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Thanks.
Florent & Francois
Hi Jose,
2014-02-20 16:15 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com…437…>:
Hi Francois
For the time being the widget editor is still available from the metadata contextual menu in other actions. I’ll add a JS settings to have it on the menu or not.
Yes.
I made the exercise last week for iso19139.fra and for simple schema it consists of configuring the layout.
For this schema all is delegated to iso19139 so it could be a good starting point for others.
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.fra/layout
Cheers.
Francois
Jose García
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Thanks.
Florent & Francois
Hi Jose,
2014-02-20 17:09 GMT+01:00 Francois Prunayre <fx.prunayre@anonymised.com>:
Hi Jose,
Settings added to enable Ext and/or Angular editor.
If there is no other comments, I’ll probably merge it to develop branch today.
Cheers.
Francois
2014-02-20 16:15 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
Yes.
Cheers.
Francois
Jose García
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Thanks.
Florent & Francois
