[GeoNetwork-devel] CFV / Metadata Massive Replace
Dear PSC,
Here is the proposal for the metadata massive replacements: https://github.com/geonetwork/core-geonetwork/wiki/Metadata-Massive-Replace
This proposal adds a new feature to apply a massive replacement process in the content of metadata records selection. The feature is focussed in iso19139 metadata, but can be extended in the future to other non iso19139 profiles.
You can find the code changes in this pull request: https://github.com/geonetwork/core-geonetwork/pull/472
Looking forward to your votes.
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
This changes looks similar to CSW Update, except it has a much nicer UI.
How is it different from CSW Property update requests (now that CSW has XPath create and delete)?
I see there is some reporting as well. That certainly seems to be one difference beyond the UI. Anything else?
Jesse
On Thu, Apr 24, 2014 at 11:30 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
GeoNetwork-devel mailing list
Hi, it also looks similar to the batch process page which are available from the admin UI https://drive.google.com/file/d/0BwyvNKYgG4ZWZV9mMUk4WU01WU0/edit?usp=sharing with some new feature like changes report but without some others like progress report.
Can’t we find a way to combine those features in the same UI ?
Also, adding too many features in the search UI make it more and more complex, I think in the future we should find a way to keep the search UI simple and move some advanced editor features to a separate page.
Francois
2014-04-24 11:30 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Francois
The original work was done for 2.6.x, not sure if batch process stuff was there and also the customer wanted some “easier” UI.
Anyway I’m in favour to integrate this feature in the batch process page, but I need to take a look how configurable is the UI to request parameters for the process. Maybe we can discuss this in IRC next week?
Jose García
On Thu, Apr 24, 2014 at 2:53 PM, Francois Prunayre <fx.prunayre@anonymised.com.> wrote:
Francois
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Francois
I have checked a bit the Angular Admin for the batch processes and I’m thinking about adding a new option next to Batch process, name Batch replacements with a similar design as the actual popup displayed in the search UI. This way the search UI is simplified and possibly more consistent to have in the administration panel.
The Batch process form seem retrieving the list of params (fixed list seem?) from the process, but for replacements seems nicer to have a more elaborated form.
Let me know if makes sense about this or otherwise what is your preference, as really would like to get the feature integrated.
Jose García
On Thu, Apr 24, 2014 at 3:14 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Francois
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2014-04-24 17:30 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
The list of parameters is configurable by process (https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/config/batch-process-cfg.json) so it could be extended to support more elaborated control for your process ? BTW MassiveReplaceContent looks quite similar to BatchXSLProcessing and combining the 2 is probably a bit of work.
So maybe for the time being, the feature should be integrated as it is… Also If we still target GN3.x to be based on Angular, it could be nice to have new proposals using it.
Cheers.
Francois
Jose García
Hi Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Francois
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
+1 from me!
Patrizia
Sent: 24 April 2014 11:31
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] CFV / Metadata Massive Replace
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Thanks Patrizia!
We have been updating the code to integrate the process in the Angular UI and support also to request the progress of the process, similar as work the generic xslt processes.
You can find the updated proposal in https://github.com/geonetwork/core-geonetwork/pull/472 and also the updated code in the pull request: https://github.com/geonetwork/core-geonetwork/pull/472
The process I think has some nice features, like a detailed report of changes done in each metadata. We can work in Bolsena to check the other xsl processes for changes required to use this detailed report in them.
Looking forward for your votes!
Jose García
On Fri, Apr 25, 2014 at 9:23 AM, Monteduro, Patrizia (NRL) <Patrizia.Monteduro@anonymised.com…> wrote:
+1 from me!
Patrizia
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
To: Devel geonetwork-devel@anonymised.coms.sourceforge.net
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
+1 for me Jose.
Francois
Hi
Thanks Patrizia!
Jose García
+1 from me!
Patrizia
Dear PSC,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
