The target of this proposal is to add a lucene-only search service to
use with the widget UI which provides much better performance (10 to
20 times
faster and better concurrency support). The proposal is available here
[1]. A patch is available here [2].
For testing, a demo website (which may be offline sometimes) is
available with the new service here [3] and the current search here
[4] or [5].
Run a search and do paging to see the differences (increase hits per
page if needed).
20 times
[4] or [5].
page if needed).
All the data continuously generated in your IT infrastructure
contains a definitive record of customers, application performance,
security threats, fraudulent activity, and more. Splunk takes this
data and makes sense of it. IT sense. And common sense. http://p.sf.net/sfu/splunk-novd2d
+1 from me - nice improvement (also the graphs in the proposal showing the perf improvements will be very useful!)
Cheers and thanks,
Simon
On 11/26/2011 04:02 AM, Francois Prunayre wrote:
Dear PSC,
20 times
[4] or [5].
page if needed).
GeoNetwork-devel mailing list
GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
This is very interesting, looks like a big performance improvement.
Just a question.
I didn't understand where the actual XML metadata documents are stored.
If not in the relational database are they stored in Lucene's files or a seperate
a collection of XML files on disc?
Andrew
----- Original Message ----- From: "Francois Prunayre" <fx.prunayre@anonymised.com>
To: <geonetwork-devel@lists.sourceforge.net>
Sent: Saturday, November 26, 2011 4:02 AM
Subject: [GeoNetwork-devel] CFV: Proposal to add a Lucene-Only search mode
Dear PSC,
20 times
[4] or [5].
page if needed).
Just a question.
No changes made on the XML documents storage. The proposal only stores
some more information in index fields in order to be able to display
search results without accessing the XML document frolm the DB.
Cheers.
Francois
seperate
Andrew
Dear PSC,
20 times
[4] or [5].
page if needed).
Alle 18:02:34 di Friday 25 November 2011, Francois Prunayre ha scritto:
Dear PSC,
20 times
[4] or [5].
page if needed).
--- All the data continuously generated in your IT infrastructure
20 times
[4] or [5].
page if needed).
Francois, if the target is the widget UI, then you should probably also expose it to the opensearch API for full text search.
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat Tel/Fax:+1 503 454-6248 Cell:+1 703 459-5860
I would like to see it extended for certain CSW searches as well if that is ok. Obviously the ones that need the full metadata can’t be done but hits and summary can be to some degree.
20 times
[4] or [5].
page if needed).
— All the data continuously generated in your IT infrastructure
Douglas D. Nebert
ok. Obviously the ones that need the full metadata can't be done but hits
Does that sound like an good idea?
Sounds good to me if you have funding to do it Jesse ! I will commit
that proposal first, probably next week and we could improve CSW,
OpenSearch, ... later when resources available.
Also for the summary in results_with_summary, I have been
investigating using Lucene facetting module [1] which is maybe a
better than our custom summary builder (and also improve
performances). But it needs some more work.
Francois
PS : I'll try to be online for IRC next week so we could discuss that if needed
On Wed, Nov 30, 2011 at 4:54 PM, Douglas Nebert <ddnebert@anonymised.com> wrote:
>> Dear PSC,
>> 20 times
>> [4] or [5].
>> page if needed).
Douglas D. Nebert
Dear François,
Nice proposal. +1 from me.
Jeroen
On 25 nov. 2011, at 18:02, Francois Prunayre wrote:
Dear PSC,
20 times
[4] or [5].
page if needed).
-----Original Message-----
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: 25 November 2011 18:03
To: Devel geonetwork-devel@lists.sourceforge.net
Dear PSC,
The target of this proposal is to add a lucene-only search service to use with the widget UI which provides much better performance (10 to 20 times faster and better concurrency support). The proposal is available here [1]. A patch is available here [2].
For testing, a demo website (which may be offline sometimes) is available with the new service here [3] and the current search here [4] or [5]. Run a search and do paging to see the differences (increase hits per page if needed).
data and makes sense of it. IT sense. And common sense. http://p.sf.net/sfu/splunk-novd2d _______________________________________________
GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
