[GeoNetwork-devel] CFV: Proposal to add plugin schemas/profiles to trunk 2.7
Dear PSC members,
Proposal to add plugin metadata profiles/schemas to GeoNetwork trunk (2.7 Unstable) is available at:
http://trac.osgeo.org/geonetwork/wiki/pluginprofiles
The changes have been tested with 2.6.0 using some Australian ISO profiles and schemas & Francois has tested it with the French ISO Profile.
There is a brief pdf presentation on how to add a plugin schema (this could be refined into a HOWTO later) attached to the proposal document.
Simon
+1 for me Simon. Great work.
Francois
2010/12/7 <Simon.Pigot@anonymised.com>:
Dear PSC members,
Simon
What happens now with your Lotus Notes apps - do you make another costly
upgrade, or settle for being marooned without product support? Time to move
off Lotus Notes and onto the cloud with Force.com, apps are easier to build,
use, and manage than apps on traditional platforms. Sign up for the Lotus
Notes Migration Kit to learn more. http://p.sf.net/sfu/salesforce-d2d
GeoNetwork-devel mailing list
Great work Simon!
+1 from me!
Mathieu
On Tue, Dec 7, 2010 at 2:17 PM, Simon.Pigot@anonymised.com wrote:
Dear PSC members,
Simon
I’m not an official developer, but I sure like the look of what is in the proposal, and I’m glad to see use of some of the work that Dominic Owen did. Please adopt!
steve
Stephen M. Richard
U S Geoscience Information Network (USGIN)
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701
USA
phone: 520 209-4127
AZGS Main: (520) 770-3500.  FAX: (520) 770-3505
email: [steve.richard@anonymised.com](mailto:steve.richard@anonymised.com)
+1
Thank you Simon!
-----Original Message-----
From: Simon.Pigot@anonymised.com [mailto:Simon.Pigot@anonymised.com]
Sent: 07 December 2010 14:17
To: Simon.Pigot@anonymised.com; geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] CFV: Proposal to add plugin schemas/profiles to trunk 2.7
Dear PSC members,
Simon
upgrade, or settle for being marooned without product support? Time to move off Lotus Notes and onto the cloud with Force.com, apps are easier to build, use, and manage than apps on traditional platforms. Sign up for the Lotus
GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net
Really great work!
+1
   Ciao,
   Emanuele
Alle 14:17:19 di martedì 7 dicembre 2010, Simon.Pigot@anonymised.com ha scritto:
Dear PSC members,
Simon
--- What happens now with your Lotus Notes apps - do you make another costly
Lotus Notes Migration Kit to learn more. http://p.sf.net/sfu/salesforce-d2d
Hi All,
Hopefully there is a quick answer to this question. Can GeoNetwork version 2.6 display in the OpenLayers web mapping interface Web Map Tiled Service information?
I have a contractor providing a test WMTS and I have tried to load it into the OpenLayers web mapping client in GN 2.6. I get an error message that it can't open the WMS. Unfortunately I can't make that WMTS public for others to try the test so at this stage an simple yes or no is all I can expect.
Thanks in advance for any help you can provide.
John Hockaday
Spatial Standards Group (OSDM)
Hi John
No WMTS layer support for now. Although should not be much work to extend the map to support it. You can open a ticket in http://trac.osgeo.org/geonetwork/ to include this feature in a next version.
For trac access you need an OSGeo account, if you don’t have it, check this link to create one: http://www.osgeo.org/osgeo_userid
Jose García
GeoCat bv
http://geocat.net
On Thu, Feb 10, 2011 at 12:37 AM, <john.hockaday@anonymised.com> wrote:
Hi All,
I have a contractor providing a test WMTS and I have tried to load it into the OpenLayers web mapping client in GN 2.6. I get an error message that it can’t open the WMS. Unfortunately I can’t make that WMTS public for others to try the test so at this stage an simple yes or no is all I can expect.
John Hockaday
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
Hello José,
2011/2/10 jose garcia <josegar74@anonymised.com>:
Hi John
For information, I added support for any OpenLayers layer types in the
widget sandbox if that could help to add it to trunk.
See demo with OSM :
http://opencarto.net/geonetwork/apps/search/index_debug.html
or with default WMS
Cheers.
Francois
For trac access you need an OSGeo account, if you don't have it, check this
Jose García
GeoCat bv
http://geocat.net
Hi All,
information?
John Hockaday
Hi Francois
Thanks, very good improvement. I’ll check to include in trunk also.
Jose García
On Thu, Feb 10, 2011 at 2:45 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hello José,
2011/2/10 jose garcia <josegar74@anonymised.com…31…>:
Hi John
See demo with OSM :
or with default WMS
Cheers.
Francois
Jose García
GeoCat bv
http://geocat.net
Hi All,
information?
John Hockaday
Hi Jose and Francois,
Thanks for your prompt replies. Sorry for taking so long to get back to you - I'm snowed under with other work - ;--).
We are using the widget interface. Is there some documentation or tutorial that I can read to see how to do this?
I have opened a ticket (http://trac.osgeo.org/geonetwork/ticket/454). This is my first ticket so I hope that I have followed the correct convention. ;--)
Thanks.
John
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: Friday, 11 February 2011 12:45 AM
To: jose garcia
Cc: Hockaday John; geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Can GeoNetwork version 2.6
display Web Map Tiled Service images? [SEC=UNCLASSIFIED]
Hello José,
> Hi John
work to extend
in a next version.
See demo with OSM :
or with default WMS
Cheers.
Francois
have it, check this
> Regards,
> Jose García
> GeoCat bv
> http://geocat.net
>> Hi All,
GeoNetwork version
Map Tiled Service
>> information?
to load it into
public for others
all I can expect.
>> John Hockaday
Parallel Studio XE:
development cycle.
performance.
>> _______________________________________________
Parallel Studio XE:
development cycle.
performance.
Hi John,
2011/2/16 <john.hockaday@anonymised.com>:
No documentation yet on this. And do not update your widgets if you're
using trunk.
I'm currently adding the editor to the widgets so it requires some
changes to trunk and I don't have a public patch to be applied to
trunk to add this support. I hope to provide that by the end of the
month.
To only add the tiled layers support you could have a look to that
commit [1] and [2] (unfortunately many things added in the same commit
:frowning: ).
Cheers.
Francois
[1] http://osgeo-org.1803224.n2.nabble.com/SF-net-SVN-geonetwork-7251-sandbox-guiwidgets-web-src-main-webapp-apps-td6003385.html
[2] http://osgeo-org.1803224.n2.nabble.com/SF-net-SVN-geonetwork-7252-sandbox-guiwidgets-web-src-main-webapp-apps-search-td6003395.html
Thanks.
John
To: jose garcia
Hello José,
> Hi John
work to extend
in a next version.
See demo with OSM :
or with default WMS
Cheers.
Francois
have it, check this
> Regards,
> Jose García
> GeoCat bv
> http://geocat.net
>> Hi All,
GeoNetwork version
Map Tiled Service
>> information?
to load it into
public for others
all I can expect.
>> John Hockaday
Parallel Studio XE:
development cycle.
performance.
Parallel Studio XE:
development cycle.
performance.
