[GeoNetwork-devel] CFV / Spring MVC
Dear PSC,
Here is a proposal to move from Jeeves to Spring MVC https://github.com/geonetwork/core-geonetwork/wiki/Spring-MVC
Looking forward to your votes.
Thanks.
María.
+1 from me.
Ciao,
Jeroen
On 28 jan. 2014, at 11:55, María Arias de Reyna <delawen@anonymised.com> wrote:
Dear PSC,
Thanks.
María.
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk_______________________________________________
GeoNetwork-devel mailing list
+1
Is there a concret exemple of a new mvc service ?
Here is a list of services that are used right now from new ui :
https://github.com/geonetwork/core-geonetwork/tree/refactor_editorui/web/src/main/webapp/WEB-INF/config
On Tue, Jan 28, 2014 at 12:07 PM, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
+1 from me.
Ciao,
Jeroen
Dear PSC,
Thanks.
María.
Florent Gravin
Camptocamp - Chambéry
0479444492
On Tue, Jan 28, 2014 at 12:11 PM, Florent Gravin <
florent.gravin@anonymised.com> wrote:
+1
You can find it here:
https://github.com/geonetwork/core-geonetwork/wiki/Spring-MVC#wiki-coding-example-orgfaogeonetservicesconfiggetjava
It is not a very complex service and returns xml (or json) but you can
normally use spring MVC to return html.
+1 from me.
Ciao,
Jeroen
wrote:
Dear PSC,
Thanks.
María.
Florent Gravin
0479444492
Jeeves had been developed in order to have very few dependencies (in a time
when maven did not exist yet), and the general GN architecture was designed to
require as less knowledge as possible from the ppl who had to work with it.
Nowadays is far more likely that any developer knows Spring rather than
Jeeves, so it's time to move on! :slight_smile:
Before giving my +1, I'd like to point out that, with the ol' jeeeves
architecture, it's quite useful the ability to create new services simply by
editing xml and xsl files (no need to recompile), provided that an existing
java class already generates the needed output.
I hope this kind of mechanism is retained even after the full refactoring of
all the services.
   Ciao,
   Emanuele
Alle 11:55:28 di Tuesday 28 January 2014, María Arias de Reyna ha scritto:
Dear PSC,
Thanks.
María.
Our support, Your Success!
Visit http://opensdi.geo-solutions.it for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hi Emanuele,
Spring allows you to configure new services only via xml. In addition it allows you to add new services by simply dropping a jar in that contains controllers and services. So we get many new features beyond those that Jeeves provides.
The option to create a service with @Controller in the code (for example) is simply an option not a requirement.
In my view the big advantage of this is the ability to further partition the project into modules that contain services and can be dropped into a Geonetwork installation if the features are needed but can be left out if those features are not required.
Jesse
On Wed, Jan 29, 2014 at 3:23 PM, Emanuele Tajariol <etj@anonymised.com> wrote:
Jeeves, so it’s time to move on! :slight_smile:
Before giving my +1, I’d like to point out that, with the ol’ jeeeves
architecture, it’s quite useful the ability to create new services simply by
all the services.
Ciao,
Emanuele
Dear PSC,
Thanks.
María.
Technical Lead
2014-01-29 Jesse Eichar <jesse.eichar@anonymised.com>
Hi Emanuele,
Jeeves provides.
This sounds like a nice improvements. It could be nice to do the exercise
for one part of the application and create a simple guideline so we can
progressively create modules ? There is probably different ways to do it
(?), so having a common guideline could help.
Francois
Jesse
On Wed, Jan 29, 2014 at 3:23 PM, Emanuele Tajariol <etj@anonymised.com>wrote:
time
designed to
it.
by
existing
of
all the services.
   Ciao,
   Emanuele
> Dear PSC,
> Thanks.
> María.
Technical Lead
