[GeoNetwork-devel] CFV: Vote to change harvesting schedule
Dear PSC members,
Please check the proposal http://trac.osgeo.org/geonetwork/wiki/proposals/HarvestingSchedule for voting.
Actual schedule for harvesters allow only to define an interval to run periodically the harvesters. The main disadvantage is that this interval is relative to the time the harvester is activated, being not possible to define specific hour to run it.
This proposal modifies the harvesters schedule to be similar as Lucene Index Optimizer schedule, allowing the user to define the initial hour to run them and an interval to reschedule (from 1 h to 1 week).
A patch is going to be add beginning next week.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jose,
Is the implementation already done?
Jesse
On Fri, Apr 27, 2012 at 8:55 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Dear PSC members,
voting.
Thanks and regards,
Jose García
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Hi Jesse
I did for a custom project in 2.6.X and need only some small changes to
move to trunk.
Jose García
On Fri, Apr 27, 2012 at 9:08 AM, Jesse Eichar
<jesse.eichar@anonymised.com>wrote:
Hi Jose,
Jesse
On Fri, Apr 27, 2012 at 8:55 AM, Jose Garcia <jose.garcia@anonymised.com>wrote:
Dear PSC members,
voting.
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Ok,
I have had some problems with the harvesting scheduler so on geocat I have
changed to use quartz as the scheduling mechanism. It allows cron like
definitions of when to run as well as almost any other scheduling pattern
you can imagine. It looks like your solution is a simplified version of
cron scheduling.
That is fine but my concern is the database changes. My changes do not
require any changes to the database or any migrations since it just parses
the every field either as an interval or as a cron definition. I was just
working on making a proposal for merging the Quartz work to trunk. Do you
think we can work together on this?
Jesse
On Fri, Apr 27, 2012 at 9:10 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jesse
move to trunk.
Jose García
On Fri, Apr 27, 2012 at 9:08 AM, Jesse Eichar <jesse.eichar@anonymised.com
> wrote:
Hi Jose,
Jesse
Dear PSC members,
voting.
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
PS. I am on skype and irc if you want to chat.
Jesse
On Fri, Apr 27, 2012 at 9:14 AM, Jesse Eichar
Ok,
cron scheduling.
Jesse
On Fri, Apr 27, 2012 at 9:10 AM, Jose Garcia <jose.garcia@anonymised.com>wrote:
Hi Jesse
move to trunk.
Jose García
jesse.eichar@anonymised.com> wrote:
Hi Jose,
Jesse
Dear PSC members,
voting.
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Discussions
malware
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Jose,
I really would like this option because I harvest from at least 23 nodes
around Australia. During that process I have noticed that if I am
harvesting too many nodes at one time the system runs out of memory so I
have to wait for one harvest to finish before I can start another.
It would be very nice to have the option to select many different nodes
to harvest and then run them sequentially. IE. when the harvesting of
one node finishes another will start until they have all the selected
nodes been harvested.
Have you considered adding the option to select many harvesting nodes,
add the option to sequentially harvest those nodes and also have the
option to start the harvesting process at a specific time?
Thanks.
John Hockaday
On Fri, 2012-04-27 at 08:55 +0200, Jose Garcia wrote:
Dear PSC members,
Please check the
Thanks and regards,
Jose García
details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
I am not sure if it made it to this list, but I have implemented harvesting in Geocat on Quartz scheduling. It allows for limiting the number of concurrent threads, very detailed ways to control how jobs are rescheduled if too many tasks run at the same time. Many methods of controlling when exactly the jobs are executed and how they repeat. One of the things we are going to discuss this week is how to combine that with the work that Jose did.
jesse
On Tue, May 1, 2012 at 2:50 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi Jose,
Thanks.
John Hockaday
Dear PSC members,
Please check the
Thanks and regards,
Jose García
details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Exclusive live event will cover all the ways today’s security and
Hi Jesse,
I remember seeing your post on the Quartz scheduling. It would be very
nice to include that in the harvesting options along with what Jose is
doing.
Thanks for the prompt reply.
John
jesse
        Hi Jose,
        least 23 nodes
        am
        memory so I
        another.
        different nodes
        harvesting of
        selected
        harvesting nodes,
        have the
        Thanks.
        John Hockaday
        > Dear PSC members,
        > Please check the
        > proposal
        > Actual schedule for harvesters allow only to define an
        interval to run
        > periodically the harvesters. The main disadvantage is that
        this
        > interval is relative to the time the harvester is activated,
        being not
        > possible to define specific hour to run it.
        > This proposal modifies the harvesters schedule to be similar
        as Lucene
        > Index Optimizer schedule, allowing the user to define the
        initial hour
        > to run them and an interval to reschedule (from 1 h to 1
        week).
        > A patch is going to be add beginning next week.
        > Thanks and regards,
        > Jose García
        > GeoCat Bridge for ArcGIS allows instant publishing of data
        and
        > metadata on GeoServer and GeoNetwork. Visit
        > details.
        > _________________________
        > Jose García
        > GeoCat bv
        > Veenderweg 13
        > 6721 WD Bennekom
        > The Netherlands
        > http://GeoCat.net
        > Live Security Virtual Conference
        > Exclusive live event will cover all the ways today's
        security and
        > threat landscape has changed and how IT managers can
        > will include endpoint security, mobile security and the
        latest in malware
        > threats.
        and
        Discussions
        in malware
        threats.
Dear PSC members,
The proposal http://trac.osgeo.org/geonetwork/wiki/proposals/HarvestingSchedule has been updated with Jesse additions to use use Quartz scheduler for harvesters. Also the configuration has been improved so now is possible to specify the days of week that a harvester should run. Thanks a lot to Jesse for improvements!
A patch to review is provided in http://trac.osgeo.org/geonetwork/ticket/772
Please, today we want to create branch for 2.8, so if you can vote for the proposal would be very nice to commit before creating the branch.
Thanks and regards,
Jose García
Dear PSC members,
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose and Jesse,
I have two questions about this :
(1) it’s using Quartz scheduling library. Why ? Does this use any feature that is not already available in the excellent standard Java API (ScheduledFuture, etc.) ?
(2) with this, you can specify at which exact time to start a harvester job, no matter when GN was started up. But is it still possible to define a schedule interval of e.g. 26 hours, so that after the first run, the harvester runs 2 hours later each day ?
Kind regards
Heikki Doeleman
On Tue, May 15, 2012 at 11:58 AM, Jose Garcia <jose.garcia@…437…> wrote:
Dear PSC members,
Thanks and regards,
Jose García
Dear PSC members,
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Tue, May 15, 2012 at 12:36 PM, heikki <tropicano@anonymised.com> wrote:
Jose and Jesse,
Some benefits I considered:
  • It has many features including some that could be useful for clustering. For example you could define a case where only one server does the harvesting so that multiple servers are not trying to harvest.
  • It has extremely flexible configuration for when the schedules are executed.
  • It has a cron parser,
  • It is easy to externalize the configuration of the scheduler pools (again useful for clustering).
  • Since it is designed for clustering type environments so it has solutions for managing the data required by a Job even when the job may be run on a different instance.
  • It takes into account what should be done when there are not enough threads to handle all of the jobs that are being requested
  • It has a nice solution for adding listeners for notification of job status and execution
    There are several other features but those were the main ones that jumped out at me when I was researching which solution to use.
The UI allows this and of course the Quartz backend allows this and more.
Jesse
hi Jesse,
thanks for your answers.
As for Quartz, it would be nice to know if any of its clustering support can actually be used in GeoNetwork’s clustering implementation (where only a JMS provider knows which servers participate in the clustering).
As for the 26 hour interval example, according to Jose this is not possible in the GUI for this proposal (see also proposal page). This is in contrast to the current GUI in GeoNetwork, which allows this.
Though, says Jose, it could be re-instated. In my opinion, the possibility to define a user-chosen interval should remain, as I think certain users use such intervals to move the harvester run time up by an hour or two each day.
Kind regards,
Heikki Doeleman
On Tue, May 15, 2012 at 12:50 PM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jose and Jesse,
Jesse
On Tue, May 15, 2012 at 1:33 PM, heikki <tropicano@anonymised.com> wrote:
hi Jesse,
Oh, you are correct. I incorrectly remembered the UI as I didn’t work on it so much.
Kind regards,
Heikki Doeleman
Jose and Jesse,
Jesse
Hi Jose and Jesse,
A +1 from me for this change.
Jeroen
On 15 mei 2012, at 11:58, Jose Garcia wrote:
Dear PSC members,
Thanks and regards,
Jose García
Dear PSC members,
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/_______________________________________________
+1 for me.
Thanks Jesse & Jose.
Francois
2012/5/15 Jeroen Ticheler <jeroen.ticheler@anonymised.com>:
Hi Jose and Jesse,
Jeroen
Dear PSC members,
The
for improvements!
Thanks and regards,
Jose García
Dear PSC members,
Please check the
for voting.
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
threats.
Jose & Jesse,
+1 from me
Cheers and thanks,
Simon
Sent: Tuesday, 15 May 2012 7:58 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] CFV: Vote to change harvesting schedule
Dear PSC members,
The proposal proposals/HarvestingSchedule – GeoNetwork opensource Developer website has been updated with Jesse additions to use use Quartz scheduler for harvesters. Also the configuration has been improved so now is possible to specify the days of week that a harvester should run. Thanks a lot to Jesse for improvements!
A patch to review is provided in #772 (Improve harvesters schedule (use similar configuration as for Lucene Index Optimizer schedule)) – GeoNetwork opensource Developer website
Thanks and regards,
Jose García
On Fri, Apr 27, 2012 at 8:55 AM, Jose Garcia <jose.garcia@anonymised.com<mailto:jose.garcia@anonymised.com>> wrote:
Dear PSC members,
Please check the proposal proposals/HarvestingSchedule – GeoNetwork opensource Developer website for voting.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
+1 for me.
   Ciao,
   Emanuele
Alle 11:58:32 di Tuesday 15 May 2012, Jose Garcia ha scritto:
Dear PSC members,
The proposal
improvements!
Thanks and regards,
Jose García
> Dear PSC members,
> voting.
> Thanks and regards,
> Jose García
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Ing. Emanuele Tajariol
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 3802116282
http://www.youtube.com/user/GeoSolutionsIT
