[GeoNetwork-devel] Change flow on import batch
I’m testing the r8212 from trunk, over a Postgres 9.1.0 DB.
try-ing to import some metadata using the “batch-import” procedure there is some trouble.
Infact after imported the metadata they are not available to the admin user .
The import phase report that all was ok.
I try also to drop and re-create the db to avoid some incompatibility with it.
I like to know from other user if this could be a confirmed bug.
thx,
Andrea Peri
qwerty àèìòù
