>Hi,
>I'm testing the r8212 from trunk, over a Postgres 9.1.0 DB.
>try-ing to import some metadata using the "batch-import" procedure there is
>some trouble.
>Infact after imported the metadata they are not available to the admin user
>The import phase report that all was ok.
>I try also to drop and re-create the db to avoid some incompatibility with
>it.
>I like to know from other user if this could be a confirmed bug.
>thx,
I tested a bit more this fact.
It is not really a bug.
It seem to be related to the
org.postgis.DriverWrapper
Infact using this driver the metadatas are not listed in the search tab.
Instead using the
org.postgresql.Driver
the metadata are correctly listed.
So a easy workaround is use the
