I tried to customize the UI. Everytime I try to ng-include my own header template the default header appears. I can’t find where this frigging thing is hardwired? since I’m only a beginner with Angular.
Can someone please help?
Thank you!
Gabi
Hi Gabi,
As always, let's start with the basic questions.
Are you working with the war file or with the source code?
Are you modifying the default view or adding your own?
Are you removing the wro4j cache files? (wro4j-cache.h2.db)
Does it work if you add the ?debug=true parameter to the url? As
http://…/geonetwork/srv/eng/catalog.search?debug=true
María.
On Mon, Apr 25, 2016 at 9:39 AM, gabi9001@anonymised.com
<gabi9001@anonymised.com> wrote:
template the default header appears. I can't find where this frigging thing
is hardwired? since I'm only a beginner with Angular.
Thank you!
Gabi
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers
of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
GeoNetwork-devel mailing list
