[GeoNetwork-devel] Chasing old Jeeves source code
I working with geonetwork 2.0.3 (cause I have to and am not allowed to
upgrade to 2.1) and would like to get a hold of the Jeeves source code
for the version of Jeeves that was used in this geonetwork release (the
one before Log4j). Can anyone provide me with a copy please?
Specifically I'm looking for a version of the ServiceManager class to
stop it from logging passwords, prefer one that has not been decompiled
as I have tried a few de-compilers and their all churning out different
code.
Kevin Gunn
Software Engineer
Australian Institute of Marine Science
Ph: (07) 47534305
Fax: (07) 4772 5852
E-mail: k.gunn@anonymised.com
The information contained in this communication is for the use of the
individual or entity to whom it is addressed, and may contain
information which is the subject of legal privilege and/or copyright.
If you have received this communication in error, please notify the
sender by return E-Mail and delete the transmission, together with any
attachments, from your system. Thank you.
Hi Kevin,
I see that some problems are happening because of the geonetwork-jeeves
dependancy, particularly the jeeves' version of a geonetwork version.
For the new geonetwork and jeeves versions, I will keep them aligned.
So, geonetwork 2.1 will use jeeves 2.1.
For old versions (like the one you are using) I have re-enabled CVS access
for jeeves. As far as I remember, the jeeves code for geonetwork 2.0.3
should be in the branch V2_0_FIX3.
code.
Kevin Gunn
Software Engineer
Ph: (07) 47534305
Fax: (07) 4772 5852
