Hi All,
I’ve been doing some tests on GeoNetwork RC2 and I found the following features that don’t work properly:
· The data upload does not work in Internet Explorer
· When you click on interactive map you don’t see the map appearing in the Map viewer as long as you click on the map screen
· The result page show the same list of keywords for all ISO metadata records summarized
Patrizia
Patrizia Monteduro
GeoNetwork www.fao.org/geonetwork
Food and Agriculture Organization of the UN (FAO)
Viale delle Terme di Caracalla, 1 - 00153 Rome ITALY
Room F815; Tel. +39 06 570 54769; Fax +39 06 570 53369
patrizia.monteduro@anonymised.com
Hi
I have been getting the same behaviour with RC1 for the keywords.
It seems that they are accumulated from the result of the search.
JF
Monteduro, Patrizia (SDRN) wrote:
Hi All,
I've been doing some tests on GeoNetwork RC2 and I found the following
features that don't work properly:
* The data upload does not work in Internet Explorer
* When you click on interactive map you don't see the map
appearing
* The result page show the same list of keywords for all ISO
metadata
records summarized
Patrizia
Patrizia Monteduro
<file:///C:/Documents%20and%20Settings/monteduro/Application%20Data/Microsoft
/Signatures/www.fao.org/geonetwork>
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
View this message in context: http://www.nabble.com/Checking-GN-RC2-tp15694331s18419p15765269.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
