Hi Veronica,
On Sep 7, 2006, at 1:00 PM, Veronica.Guidetti@anonymised.com wrote:
Hi Jeroen,
Wrt the GN version we're talking about yesterday,
downloading source code via CVS client cannot be done directly from my machine (due to the esa external access policy)
This is an important point; We may have to generate a nightly zipped sourcecode archive.. somthing to keep in mind when moving from CVS to SVN
and since I have to be assigned with a special account on another machine able to download from your CVS repository
I'd like to be sure in advance on which is the right MODULENAME I should check out from it (i.e. GN version that validates against ISO19139).
You have to check out the HEAD to get the latest source code.
Could you please provide me with it?
I browsed the repository via the web interface: is "geonetwork/" the right place?
I'll check it out with an anonymous CVS access, is that correct?
Yes, correct
Thanks a lot!
Veronica
