Excellent! Forwarding this to the list so others can benefit when using the latest CVS code.
Ciao,
Jeroen
On 16 Nov 2005, at 13:52, Roberto Giaccio wrote:
Dear GeoNetworkers,
I have just finished writing a small application that compares all localized files and checks for;- files available in main language but missing in localized directory
- extra files in localized directory not present in main language directory
- in addition, if a file is xml, both the main language and localized document are loaded, and the application checks for:
- elements (root children) available in main language but missing in localized document
- elements(root thildren) in localized document not present in main language document
- if the file is xml and contains errors (like bad UTF, encoding) an error message is displayed.The program is executed with the following commands:
cd GEONETWORK_WEBAPP_DIR (usually .../geonetwork/web)
java -cp WEB-INF/lib/geonetwork.jar:WEB-INF/lib/jeeves.jar:WEB-INF/lib/jdom.jar org.fao.geonet.apps.CheckLocalizedFiles loc/ enYou can find below the output for the current french and spanish files; the french translation is almost ok, but the spanish one needs some revision; who is going to revise the two translations?
Finally, note that the following files in the french and spanish translations are actually in english:
metadata-validate.xml
validation-error.xmlIt would be nice to add some minimal graphical user interface so that the application cann be started by double clicking the jar file.
See you tomorrow.Roberto
LOCALIZED FILES REPORT
main language: en
additional languages
- es
- frmain language files
scanning files for language 'es'
- xml/privileges-error.xml
- xml/help.xml
- xml/error.xml
- xml/login-error.xml
- xml/iso-languages.xml
- xml/metadata-thumbnail.xml
- xml/metadata-searchunused.xml
- xml/file-too-big-error.xml
- xml/metadata-create.xml
- xml/fgdc-std.xml
- xml/password-changed.xml
- xml/feedback-sent.xml
- xml/metadata-validate.xml
- images/search-white.gif
- xml/dublin-core.xml
- xml/size-error.xml
- xml/file-not-found-error.xml
- images/nopreview.gif
- xml/category-names.xml
- xml/validation-error.xml
- xml/links.xml
- images/search-blue.gif
- xml/about.xml
- xml/metadata-delete.xml
- xml/service-not-found-error.xml
- xml/iso19115.xml
**** element <aName> is missing
**** element <attributeType> is missing
**** element <begin> is missing
**** element <Binary> is missing
**** element <Boolean> is missing
**** element <calDate> is missing
**** element <catFetTypes> is missing
**** element <CellGeoCd> is missing
**** element <CharacterString> is missing
**** element <CharSetCd> is missing
**** element <ClasscationCd> is missing
**** element <clkTime> is missing
**** element <cntOnLineRes> is missing
**** element <ContentTypCd> is missing
**** element <conversionToISOstandarUnit> is missing
**** element <coordinates> is missing
**** element <coordSep> is missing
**** element <DatatypeCd> is missing
**** element <Date> is missing
**** element <DateTime> is missing
**** element <DateTypCd> is missing
**** element <dateType> is missing
**** element <datumID> is missing
**** element <days> is missing
**** element <Decimal> is missing
**** element <decimalChar> is missing
**** element <designator> is missing
**** element <dimension> is missing
**** element <DimNameTypCd> is missing
**** element <Distance> is missing
**** element <distFormat> is missing
**** element <distroTran> is missing
**** element <DQElementTypes> is missing
**** element <eleDatatype> is missing
**** element <end> is missing
**** element <EvalMethTypeCd> is missing
**** element <evaluationProcedure> is missing
**** element <extDomcode> is missing
**** element <fetCatSup> is missing
**** element <GenericNameTypes> is missing
**** element <GeoObjTypCd> is missing
**** element <GM_Point> is missing
**** element <GM_Polygon> is missing
**** element <hours> is missing
**** element <ImgCondCd> is missing
**** element <Integer> is missing
**** element <KeyTypCd> is missing
**** element <languageCode> is missing
**** element <LocalName> is missing
**** element <MaintFreqCd> is missing
**** element <MdIdentTypes> is missing
**** element <Measure> is missing
**** element <measureDescription> is missing
**** element <MedFormCd> is missing
**** element <MedNameCd> is missing
**** element <MemberName> is missing
**** element <minutes> is missing
**** element <months> is missing
**** element <NumberTypes> is missing
**** element <ObCd> is missing
**** element <OnFunctCd> is missing
**** element <onLineMed> is missing
**** element <PixOrientCd> is missing
**** element <precision> is missing
**** element <PresFormCd> is missing
**** element <ProgCd> is missing
**** element <quanVal> is missing
**** element <RangeDimTypes> is missing
**** element <Real> is missing
**** element <Record> is missing
**** element <refDateType> is missing
**** element <refSysName> is missing
**** element <RefSystemTypes> is missing
**** element <RestrictCd> is missing
**** element <ResultTypes> is missing
**** element <RoleCd> is missing
**** element <RS_Identifier> is missing
**** element <SC_VerticalDatum> is missing
**** element <scope> is missing
**** element <ScopeCd> is missing
**** element <ScopedName> is missing
**** element <seconds> is missing
**** element <SpatRepTypCd> is missing
**** element <SpatRepTypes> is missing
**** element <stanPara> is missing
**** element <status> is missing
**** element <TempExtentTypes> is missing
**** element <Time> is missing
**** element <timeIndicator> is missing
**** element <TM_CalDate> is missing
**** element <TM_ClockTime> is missing
**** element <TM_DateAndTime> is missing
**** element <TM_GeometricPrimitive> is missing
**** element <TM_Instant> is missing
**** element <TM_Period> is missing
**** element <TM_PeriodDuration> is missing
**** element <TM_PositionTypes> is missing
**** element <TM_Primitive> is missing
**** element <tmPosition> is missing
**** element <TopicCatCd> is missing
**** element <TopLevCd> is missing
**** element <tupleSep> is missing
**** element <TypeName> is missing
**** element <UnitOfMeasureTypes> is missing
**** element <uom> is missing
**** element <UomAngle> is missing
**** element <UomArea> is missing
**** element <UomLength> is missing
**** element <uomName> is missing
**** element <UomScale> is missing
**** element <UomTime> is missing
**** element <UomVelocity> is missing
**** element <UomVolume> is missing
**** element <URL> is missing
**** element <value> is missing
**** element <years> is missing
**** extra element <cntOnlineRes>
**** extra element <eleDataType>
**** extra element <extDomCode>
- xml/strings.xml
**** element <assigned> is missing
**** element <backToEditor> is missing
**** element <createTip> is missing
**** element <helpComplete> is missing
**** element <interMapInfo> is missing
**** element <mdUpdateError> is missing
**** element <messageMdUpdateError> is missing
**** element <metadataJSForm> is missing
**** element <newCategory> is missing
**** element <none> is missing
**** element <noLogin> is missing
**** element <searchTemplates> is missing
**** element <updateCategory> is missing
**** element <wwwlink> is missing
**** extra element <batchImportDesc>
**** extra element <buttonAccept>
**** extra element <buttonAdd>
**** extra element <buttonAddNewGroup>
**** extra element <buttonAddNewUser>
**** extra element <buttonAdvancedSearch>
**** extra element <buttonBack>
**** extra element <buttonBatchImport>
**** extra element <buttonBrowse>
**** extra element <buttonCancel>
**** extra element <buttonClear>
**** extra element <buttonCreate>
**** extra element <buttonDecline>
**** extra element <buttonDefaultSearch>
**** extra element <buttonDelete>
**** extra element <buttonDescription>
**** extra element <buttonDownload>
**** extra element <buttonEdit>
**** extra element <buttonGroupManagement>
**** extra element <buttonImport>
**** extra element <buttonInsertXMLMetadata>
**** extra element <buttonInteractiveMap>
**** extra element <buttonLogin>
**** extra element <buttonMap>
**** extra element <buttonNewMetadata>
**** extra element <buttonPrint>
**** extra element <buttonPrivileges>
**** extra element <buttonRemove>
**** extra element <buttonReset>
**** extra element <buttonSave>
**** extra element <buttonSaveAndClose>
**** extra element <buttonSearch>
**** extra element <buttonSubmit>
**** extra element <buttonTabbedView>
**** extra element <buttonUpload>
**** extra element <buttonUserManagement>
**** extra element <copyright3>
**** extra element <count>
**** extra element <intermapHelpTitle>
**** extra element <intermapHelpText1>
**** extra element <intermapHelpText2>
**** extra element <mapServer>
**** extra element <metadataPerRegion>
**** extra element <xmlMetadataInsert>
**** extra element <wwwlinks>
**** extra element <xmlInsertDesc>
**** extra element <orderBy>
**** extra element <rank>
**** extra element <downloads>
**** extra element <lastChange>scanning files for language 'fr'
- xml/help.xml
- xml/error.xml
- xml/fgdc-std.xml
- xml/links.xml
- xml/about.xml
- xml/iso19115.xml
- xml/strings.xml
