[GeoNetwork-devel] Code provenance review
I worked on the code provenance review and wrote down the process as it was followed until now.
I could use some help in completing the components dependencies review (http://wiki.osgeo.org/index.php/GeoNetwork_Library_Review#External_dependencies) it this is not a complex work, but takes some time to write down for each component what license it uses and (if possible directly, otherwise later) determine if this license does cause conflicts with the GeoNetwork opensource GPL license.
The full process is described hare: http://wiki.osgeo.org/index.php/GeoNetwork_Provenance_Review
While the incubation process is described at: http://wiki.osgeo.org/index.php/GeoNetwork_Incubation_Status
Ciao,
Jeroen
