[GeoNetwork-devel] codelist are loosing text() portions
The codelists such as the following
     <gmd:LanguageCode codeList="http://www.loc.gov/standards/iso639-2/&quot;
codeListValue="eng">English</gmd:LanguageCode>
are being converted to
codeListValue="eng"/>
or
     <gmd:MD_CharacterSetCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_CharacterSetCode&quot;
codeListValue="utf8">utf8</gmd:MD_CharacterSetCode>
is being converted to
codeListValue="utf8"/>
I know how to fix this in "update-fixed-info.xsl" - by simply applying a
"<xsl:apply-templates select="node()"/>" to the codelist templates.
If I make the change then the text portion is no longer removed (which is
good). However when editing the language (i.e.: change English to French) I
end with a situation where the text portion is out of sync
codeListValue="fre">English</gmd:LanguageCode>
I suspect that to update the text portion during editing is a bigger change
(I'm a little lost with this change).
I was wondering if this was done on purpose - can anyone tell me if this a
bug or a feature?
Thank you
View this message in context: http://osgeo-org.1560.n6.nabble.com/codelist-are-loosing-text-portions-tp4986235.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
