[GeoNetwork-devel] Commit git problematic
I am adding the mailing to this conversation so people can learn from it.
I am having to learn a little about submodules as well and am slowly getting used to it.
There are a few things to remember
  1. The submodules are cloned as read-only so that anyone can clone the main repository
  2. When a submodule is checked out it is in detached head state which means it is not on a branch.
As I see it there are 2 ways of working on a submodule.
  1. Checkout the submodule as read-only in a separate folder and work on it there and commit using that branch
  2. Each time you want to edit a submodule make it read-write, make and push change, make it read-only again.
Here are the steps for the two methods:
=== Separate clone of submodule ===
(not tested)
Note this example only shows how to do the work on one branch so if you want the commit on 2.8.x as well you have to cherry-pick the commit to that branch and update the references on core-geonetwork 2.8.x branch as well.
  1. edit submodule
  2. commit and push submodule
  3. switch to core-geonetwork
  4. git submodule update
  5. git status (if it works as expected it should show that the submodule has changed)
  6. git add
  7. git commit -m “updated submodule reference to contain commit with the bug fix …”
  8. git push
=== Edit submodule in place ===
(tested)
  1. edit .gitmodules (change git://github.com/ to git@anonymised.com:slight_smile:
  2. git sync
  3. git update
  4. cd submodule
  5. git checkout master (or 2.8.x)
  6. make changes and commit
  7. git checkout 2.8.x
  • (if you want the change on 2.8.x as well)1. git log master
  • find commit you want to merge to 2.8.x1. git cherry-pick
  1. git push
  • (will push changes to both 2.8.x and master)1. cd …
  • (back to core)1. git checkout 2.8.x
  • (submodule is on 2.8.x now so you need to update 2.8.x reference)1. git add
  1. git commit -m “updated submodule reference to contain commit with the bug fix …”
  2. git checkout master
  3. cd submodule
  4. git checkout master
  5. cd …
  6. git add
  8. git co – .gitmodules (revert .gitmodules to read-only urls again)
  9. git submodule sync
  10. git submodule update
I will try to make some video tutorials for these workflows when I have time. I will also try out some of the tools.
Jesse
On Tue, Jun 19, 2012 at 9:55 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jesse
Trying to commit in docs submodule I get this:
Pushing to git://github.com/geonetwork/core-doc-sources.git
fatal: remote error:
You can’t push to git://github.com/geonetwork/core-doc-sources.git
Use git@anonymised.com.:geonetwork/core-doc-sources.git
Any idea? I tried with 2 different Git apps and same error.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jesse, I've tested one of the method
2012/6/20 Jesse Eichar <jesse.eichar@anonymised.com>:
used to it.
repository
(not tested)
I tested that option :
edit submodule
this made nothing.
but
cd submodule
git pull origin master
cd ..
changed)
git add <submodule directory>
git commit -m "updated submodule reference to contain commit with the bug
fix ...."
git push
And it works.
Francois
(tested)
edit .gitmodules (change git://github.com/ to git@anonymised.com:)
git sync
git update
cd submodule
git checkout 2.8.x
git log master
git cherry-pick <commit>
git push
cd ..
(back to core)
git checkout 2.8.x
git add <submodule>
fix ...."
git checkout master
cd submodule
git checkout master
cd ..
git add <submodule>
fix ...."
git co -- .gitmodules (revert .gitmodules to read-only urls again)
git submodule sync
Jesse
Hi Jesse
  You can't push to git://github.com/geonetwork/core-doc-sources.git
  Use git@anonymised.com:geonetwork/core-doc-sources.git
Thanks and regards,
Jose García
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
