[GeoNetwork-devel] config-gui.xml
Resend in case anyone missed it (as I didn’t get any responses!)
Justin.
Sent: 02 August 2010 15:11
To: ‘geonetwork-devel@anonymised.comsourceforge.net’
Subject: config-gui.xml
I’ve just deployed GeoNetwork onto a Unix server, and I find that the geoserver requests are still directed to localhost:8080.
I assume I have to alter the values in config-gui to correct this. Unfortunately, this is inside the geoserver.war, which means either unzip, alter re-zip, or make a build specific to the target machine by editing before building.
Should this be part of the install process? Should this be considered a bug/enhancement?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
