[GeoNetwork-devel] Config.xml for languages
Hi All,
First of all happy new year.
Secondly, I would just like to point out that ISO 19115 stipulates in the
data dictionary that ISO 639-2 should be used for the "language" element .
That is, the three letter code for languages. EG. "eng".
Probably now is a good time to switch to the three letter code. Just a
suggestion. ;--)
Thanks.
John
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] On
Behalf Of François Prunayre
Sent: Tuesday, 2 January 2007 10:02 PM
To: 'Tim Jacobs'; geonetwork-devel@lists.sourceforge.net;
'Monteduro, Patrizia (SDRN)'
Subject: Re: [GeoNetwork-devel] Config.xml for languages
Patrizia, we already have long name in the main page. Do you
know other
pages which are displaying short name ?
Not really Tim, I would like to have a list of languages
supported by the
current node and that configuration should be set up easily by the
administrator. We already have a complete list of languages
in the ISO19115
schema.
For instance, if you want to change default language, you
need to edit the
config.xml; if you want to hide or add languages in the
banner, you need to
update the banner.xsl; and now I need a list of language available for
thesaurus.
So I would prefer to have all this options into the config.xml.
Clearly we will continu to use ISO_639 ... and maybe move to
alpha-3 code
space ...
Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la
part de Tim
Jacobs
Envoyé : mardi 2 janvier 2007 11:10
À : fx.prunayre@anonymised.com; geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Config.xml for languages
Hi Frangois,
Happy New Year to you too!
If I understand you correctly, you want to have a more or
less complete list
of language codes like "en", "fr", etc, to add them to
config.xml, right?
Those are defined by ISO, and more or less copied by IANA
(USA) for web/XML
use.
Check out for instance:
http://en.wikipedia.org/wiki/ISO_639 and the further links on
that page.
Greetings,
Tim
>From: Frangois Prunayre <fx.prunayre@anonymised.com>
>To: <geonetwork-devel@lists.sourceforge.net>
>Subject: [GeoNetwork-devel] Config.xml for languages
>Date: Tue, 2 Jan 2007 10:52:55 +0100
>Hi list (& happy new year 2oo7),
>I'm currently working on the integration of thesaurus manager into
>Geonetwork.
>For thesaurus editing, I need to have a list of languages
available for
>user.
>I would like to change the config.xml for language which is :
><language>en</language>
>which only set up the default language as "en" for example.
>by something like :
><languages>
> <language default="true" thesaurus="true">en</language>
> <language thesaurus="true">fr</language>
> <language>es</language>
> <language>cn</language>
></languages>
>which will set :
>- default language "en"
>- language available for thesaurus edition "en" and "fr"
>- languages available for the application : "en","fr","es","cn".
>That way we could also manage to remove language from the menu using
>the config.xml and not using the XSL banner.xsl.
>Any comments ?
>I hope to be able to have a first online demo for thesaurus
next week.
>Cheers
>Francois
>Ce message a ete verifie par MailScanner pour des virus ou des
>polluriels et rien de suspect n'a ete trouve.
>Les donnees et renseignements contenus dans ce message sont
personnels,
>confidentiels et prives. Toute publication, utilisation ou
diffusion,
>meme partielle, doit etre autorisee.
>Any data and information contained in this electronic mail
is personal,
>confidential and secret. Any total or partial publication, use or
>distribution must be authorized.
>-- Take Surveys. Earn Cash. Influence the Future of IT Join
>SourceForge.net's Techsay panel and you'll get the chance to
share your
>opinions on IT & business topics through brief surveys - and
earn cash
>http://www.techsay.com/default.php?page=join.php&p=sourceforg
e&CID=DEVD
>EV
>_______________________________________________
>GeoNetwork-devel mailing list
>GeoNetwork-devel@lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
>GeoNetwork OpenSource is maintained at
>http://sourceforge.net/projects/geonetwork
_________________________________________________________________
Who is the sweetheart of the Japanese and always holds
something in his
hands? Live Search knows! How about you?
http://search.live.com/images/results.aspx?q=Manneken%20pis&FORM=QBIR
des polluriels et
personnels,
diffusion, meme
Any data and information contained in this electronic mail is
personal,
des polluriels et rien de suspect n'a ete trouve.
personnels, confidentiels et prives. Toute publication,
utilisation ou diffusion, meme partielle, doit etre autorisee.
personal, confidential and secret. Any total or partial
publication, use or distribution must be authorized.
Join SourceForge.net's Techsay panel and you'll get the
chance to share your
opinions on IT & business topics through brief surveys - and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge
&CID=DEVDEV
Hi John,
we are glad to have your feedback and we try to make changes you suggest
as we can. I have just changed the metadata root element from DS_DataSet
to MD_Metadata and I will address the language codes before the final version.
Looking into the 19139 schema, I have found that into the codelist files there
are only 2 languages (english and francaise). Does anybody have a list of those
codes (better in the same 19139 codelist format with short names) ?
Hi All,
suggestion. ;--)
Thanks.
John
