[GeoNetwork-devel] ConfigOverride proposal
I think the conversation is starting to slow down now and I wondering
if we can put it up to a vote now? If you want to review the proposal
and associated ticket (which has most of the discussion) the links
are:
http://trac.osgeo.org/geonetwork/wiki/ConfigOverride
http://trac.osgeo.org/geonetwork/ticket/513
Jesse
Hi Jesse,
0 for me.
I like the idea of setting the configuration for the different type of
deployment and its definitely a place for improvement. But as
discussed yesterday a bit on IRC [1], for me, my main concern is about
what will happen with future modules as we have the idea of
progressively moving away from Jeeves (even if this will not happen
right now) at least for some components. Maybe there're some other
options to set deployment configuration (for Jeeves based modules and
others) like using Maven profiles [2] and resources filtering for
example (I'm not an expert on that).
So I don't think I'll use it but no objection to add it if others want
to have it in.
Cheers.
Francois
[1] http://logs.qgis.org/geonetwork/%23geonetwork.2011-05-31.log
[2] http://maven.apache.org/guides/introduction/introduction-to-profiles.html
2011/5/31 Jesse Eichar <jesse.eichar@anonymised.com>:
are:
Jesse
Simplify data backup and recovery for your virtual environment with vRanger.
Installation's a snap, and flexible recovery options mean your data is safe,
secure and there when you need it. Data protection magic?
Nope - It's vRanger. Get your free trial download today.
http://p.sf.net/sfu/quest-sfdev2dev
GeoNetwork-devel mailing list
+1 from me Jesse - I can see this being of use in a number of test/dev/production deployments we have.
Cheers and thanks,
Simon
________________________________________
Sent: Tuesday, 31 May 2011 5:31 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] ConfigOverride proposal
are:
Jesse
+1 from me
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
HTTP://GeoCat.net
Send from mobile phone.
Op 31 mei 2011 om 09:31 heeft Jesse Eichar <jesse.eichar@anonymised.com> het volgende geschreven:
are:
ConfigOverride – GeoNetwork opensource Developer website
#513 (ConfigOverride Proposal) – GeoNetwork opensource Developer website
Jesse
