[GeoNetwork-devel] Constantly adding layers to map
Hi Developers,
I’m using Geonetwork 3.0.x and I have an issue with the “Adding layers to map” spinner, which seems to be stuck trying to load 3 layers. This has persisted through multiple tomcat7 restarts, cache deletions etc. Admittedly there is a problem with the layers it’s trying to load, but how do I stop it from showing them? If the setting is persistent, is it stored in the database somewhere?
You can see this in action at http://ssdi.astuntechnology.com/geonetwork/srv/eng/catalog.search#/map
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Can someone provide me with some guidance as to how to stop this from happening? Geonetwork is still trying to add layers to the map and this has persisted through several tomcat7 restarts. Where is the information stored about the layers it’s trying to load?
Thanks
Jo
On Thu, Aug 4, 2016 at 12:07 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi Developers,
Thanks
Jo
Jo Cook
Jo Cook
Hi Jo
The map configuration is not stored in the server side. Afaik, is used in the local storage of the browser, in owsContext property. In Chrome you can open the dev Tools:
Inline image 2
You can cleanup the local storage from there, usually cleaning the cache should do it (try also to a private windows). With a clean cache, the context loaded should contain only the base map. So unless these layers have any issue, should work.
Jose García
On Fri, Aug 12, 2016 at 11:02 AM, Jo Cook <jocook@anonymised.com> wrote:
Thanks
Jo
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Hi Developers,
Thanks
Jo
Jo Cook
Jo Cook
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hi Jose,
I’ve dug into the dev tools in chrome and found the owscontext key but even if I delete it the issue comes back without me trying to add any new layers. I’ll investigate further to see what the actual layers are.
Thanks
Jo
(attachments)
On Fri, Aug 19, 2016 at 2:31 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Inline image 2
Jose García
Thanks
Jo
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Developers,
Thanks
Jo
Jo Cook
Jo Cook
Jo Cook
