Hi James,
Are you aware of the major differences between the trunk/build.xml and BlueNetMEST/build.xml?
As I am primary author of BlueNet/build.xml and will shortly be departing Geoscience Australia I should probably provide the group with some insight into why the differences exist and what I was hoping to achieve by making them.
The trunk/build.xml has the following advantages:
short
simple
works!
Is disadvantages are:
compiles Java to .build (directory hidden on some OS’s)
deletes .build at end of targets (causes problems in tools like Eclipse, .class files removed)
performs ‘in place’ updates of generated jar files (updates ‘source’ tree, potential pollution of SVN repository if checked in)
It was the in place updates that prompted me to rework the BlueNet build. Rather than use .build as the location for classes a build directory was introduced. Changing the name unsures the directory is not hidden. The build directory is kept at build end (unless explicitly removed by calling the clean target). I have Eclipse and Ant happily sharing the build directory, no more tool issues.
I feel quite strongly about mixing source files with generated content. It generally makes a real mess of any repository and is an opportunity for library version issues to creep in. The dist directory was introduced to separate source files from generated content. Geonetwork.jar and other files are built here. Static content from web/geonetwork (and others) are copied here and then merged with the generated JAR files. The contents of dist/web/* are deployable and this is where I have Tomcat configured to run from. It also has the effect of keeping the server logs clear of the source tree, a problem you seem to have encountered.
Building this way does have disadvantages:
It breaks ‘hot edit’, a server running against dist is working with a copy of the source files. Editing these files yields immediate changes in the website but files are overwritten in the next build (developer must copy back changes)
The build itself becomes more complex, more targets are used
The Gast utility breaks as it has a classloader structure hardcoded to the old build structure (solvable, use Gast from the installer)
Future Ideas
Move dependent JAR files from individual application WEB-INF/lib directories to a common lib directory. The intent of this is to remove jar file duplication among the three GN applications and simplify the upgrading of third party libraries.
The use of Maven has been mentioned. If people decide not to use Maven then I would suggest the introduction of Apache Ivy. This will force developers to document
direct dependencies on third party libraries (and their context, be it runtime, build or test)
clear indication of transitive dependencies (i.e. third party library requires another library)
It will also highlight any library incompatibilities, a common problem with complex projects that use numerous jars.
More work is required on the gast utility, the way it loads classes needs to be reviewed.
Stephen
-----Original Message-----
From: James.Dempsey@anonymised.com [mailto:James.Dempsey@anonymised.com]
Sent: Wednesday, 15 October 2008 5:42
To: Jeroen.Ticheler@anonymised.com.; geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Continuous Integration builds
Hi Jeroen,
Based on the failure message it sent out after my commit I think the BlueNetMEST build is running installer/build.xml rather than build.xml. Alternatively it could be running build.xml from the root folder with the all or installer targets, but that should be doing the war build also. Without seeing the full output it is difficult to tell which is the case.
James Dempsey
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Wednesday, 15 October 2008 8:24 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Continuous Integration buildsHi all,
I set up Continuous integration for three GeoNetwork builds now:
Trunk
ebXML related developments under the 3.0.x branch
BlueNetMEST branch
You can find the build status page at: http://buildtest.osgeo.org/osgeo/geonetwork/hudson/
The BlueNetMEST build failed the first time due to a missing file that’s actually generated at runtime. Not sure why, but leave it up to Simon to look into it.
Hope this is helpful. An email will be send to the commit mailinglist and to the committer in case a build breaks due to a new commit. The system does an hourly check for new commits.
Jeroen
Jeroen Ticheler
GeoCat bv
Grotenhuisweg 617384 CT Wilp
Tel: +31 (0)6 81286572
Please consider the environment before printing this email.
