Hi in develop branch, sometimes you could get “Could not commit JPA transaction”. In that case the stack trace does not indicate any location to find the root cause. Only running in debug mode could help (but sometimes debug mode is not easy to setup). Could we improve that to help solving those type of errors ?
Cheers.
Francois
java.lang.RuntimeException: Exception raised
Caused by:
org.eclipse.jetty.servlet.ServletHolder$1: java.lang.RuntimeException: Exception raised
at org.eclipse.jetty.servlet.ServletHolder.makeUnavailable(ServletHolder.java:483)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:537)
at org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:331)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:742)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:265)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:710)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293)
at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95)
at org.eclipse.jetty.server.Server.doStart(Server.java:280)
at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65)
at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:520)
at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:365)
at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:523)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:133)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:108)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:76)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:116)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:361)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:213)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:157)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:622)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: java.lang.RuntimeException: Exception raised
at jeeves.server.JeevesEngine.handleStartupError(JeevesEngine.java:213)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:91)
at javax.servlet.GenericServlet.init(GenericServlet.java:244)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:519)
… 42 more
Caused by: org.springframework.transaction.TransactionSystemException: Could not commit JPA transaction; nested exception is javax.persistence.RollbackException: Transaction marked as rollbackOnly
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:522)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:695)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:91)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:631)
at org.springframework.orm.jpa.JpaTransactionManager$$EnhancerByCGLIB$$c9e5210e.doCommit()
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:755)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:724)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:475)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:270)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:94)
at jeeves.server.JeevesEngine$$EnhancerByCGLIB$$c81f6d3c.init()
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:83)
… 44 more
Caused by: javax.persistence.RollbackException: Transaction marked as rollbackOnly
at org.hibernate.jpa.internal.TransactionImpl.commit(TransactionImpl.java:74)
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:513)
… 65 more
Caused by:
I have given this some thought. It is essentially because we have nested @Transactional annotations.
Consider when an exception occurs in DataManager. The exception will rollback the transaction in DataManager. Then the exception will be re-thrown and caught by ServiceManager’s @Transactional annotation. The block notices the transaction was already rolled back and it throws the rollbackOnly exception…
My plan is to replace @Transaction in ServiceManager and probably HarvestManager as well with a Transaction Template call to try to fix this. It will probably require some experimentation before it works.
Jesse
On Wed, Mar 5, 2014 at 11:05 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Cheers.
Francois
Caused by:
… 42 more
… 44 more
… 65 more
Caused by:
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Thanks Jesse for sharing your ideas on that. I usually get the error when there is something wrong with the db (like db user does not have privileges on tables).
Similar error hard to track, is when db user connection fails (eg. wrong password).
On tomcat it fails with SEVERE: Error listenerStart and and nothing else.
Adding WEB-INF/classes/logging.properties with
org.apache.catalina.core.ContainerBase.[Catalina].level = INFO
org.apache.catalina.core.ContainerBase.[Catalina].handlers = java.util.logging.ConsoleHandler
will at least report the error in console. Maybe we should add that to develop ?
Francois
2014-03-05 12:35 GMT+01:00 Jesse Eichar <jesse.eichar@anonymised.com>:
Jesse
Cheers.
Francois
Caused by:
… 42 more
at org.springframework.orm.jpa.JpaTransactionManager$EnhancerByCGLIB$c9e5210e.doCommit()
at jeeves.server.JeevesEngine$EnhancerByCGLIB$c81f6d3c.init()
… 44 more
… 65 more
Caused by:
On Wed, Mar 5, 2014 at 4:45 PM, Francois Prunayre <fx.prunayre@anonymised.com>wrote:
2014-03-05 14:02 GMT+01:00 Jesse Eichar <jesse.eichar@anonymised.com>:
Just so you know the "actual' error is usually logged to the file the
other (not useful error) is logged to the console
So we should not look into the console and only logs/geonetwork.log ? If
we have all information in geonetwork.log, no need to change it. Maybe we
should have same level in console and log file ? and create on log4j config
for dev and prod so user can easily switch to one level to another ?
It seems to me that this problem is a code smell and will probably result
in hard to detect errors (and probably does cause some that we don't
currently realize at the moment). For the short term we can do this
logging change but I think this needs to be fixed.
