[Geonetwork-devel] Create templates
Hi.
I'd want to known if there is a way to create, modify or delete the application's metadata intial templates (or if it is going to be supported in the near future). I mean, not in the same way it is done now but being able to change the template tags, creating a new XML format (e.g. not starting from ISO-19115).
If not possible how can I create a new template (with its own tags) and use it with the application? Like the "Template for Raster Data" or the "Template for Vector Data". I already know the template is stored in the "data" field from the "Metadata" table and the structure stored in "web/xml/schemas", "web/loc/en" and "web/locl/es/xml", however I need more info to create the new template.
Thanks in advance.
Alejandro Dobarro.
Hi Alejandro,
Sorry for this very late reply. Not sure you've seen an answer before?
Anyway, the short answer is:
1- yes it is possible and there will be a guideline how to do that. The document is in the works.
2- it is rather complex depending on how far this should be done. It requires writing a number of XSL documents to enable the displaying, editing, indexing and searching.
Hope this helps,
Ciao,
Jeroen
On 20 Oct 2005, at 14:06, Alex wrote:
Hi.
Thanks in advance.
Alejandro Dobarro.
This SF.Net email is sponsored by:
Power Architecture Resource Center: Free content, downloads, discussions,
and more. http://solutions.newsforge.com/ibmarch.tmpl
Geonetwork-devel mailing list
Geonetwork-devel@lists.sourceforge.net
Hi!
I've been into the procedure of making a shema/template from scratch... and
I wrote a little Howto...
Geonetwork shema/template Howto
« Howto create and add custom shemas to geonetwork using xml, xsl, xsd and
xpath »
Before you even start thinking about creating a new shema/template for
geonetwork, I strongly suggest you to read all of the tutorial about XML,
Xpath, XSL and XSD on w3schools.com
xml : http://www.w3schools.com/xml/default.asp
xpath : http://www.w3schools.com/xpath/xpath_syntax.asp
xsl : http://www.w3schools.com/xsl/xsl_languages.asp
xsd : http://www.w3schools.com/schema/default.asp
Otherwise, you will probably get confused and never be able to fully
understand what you’re doing.
1 – General structure : organisation_template.xml
Create a folder named exacly like your template name « organisation » in
[geonet_root]/web/xml/shemas/ Here you will store various files mandatory
to any geonetwork shema.
Start by thinking and writing down the XML structure of the metadata you
would like to show with your shema. Let say I whant to add a shema that let
geonetwork users enter information about any organisation. The basic XML
would look like this.
*Note that any metadata file that is published in geonetwork MUST have a
unique universal id (UUID). The shema you’re creating will need one, since
geonetwork considers shema as an other metadata. To get one, you can visit
the International Telecommunication Union at :
http://www.itu.int/ITU-T/asn1/cgi-bin/uuid_generate
*Note that according to the w3c stantard, all xml files must start with
<?xml version="1.0" encoding="UTF-8"?>. Since this file will be place in the
database and rearanged by the geonetwork’s api implementation, there is no
need for the xml version declaration. Geonetwork will add the appropricate
xml version declaration when needed.
<metadata>
        <orgTitle>New organisation</orgTitle>
        <orgAcronym/>
        <orgParentInstitution/>
        <orgDesc/>
        <orgSuppInfo/>
        <orgContactus>
            <orgAddress/>
            <orgPOBox/>
            <orgCity/>
            <orgPostalcode/>
            <orgProvince/>
            <orgCountry/>
            <orgPhone/>
            <orgFax/>
            <orgWebsite/>
            <orgEmail/>
        </orgContactus>
        <orgContactInfo>
            <orgContactName/>
            <orgContactRole/>
            <orgContactEmail/>
            <orgContactPhone/>
        </orgContactInfo>
        <mdFileID>d5750700-1da8-11dc-95c5-0002a5d5c51b</mdFileID>
</metadata>
Save this file as “organisation_template.xml”… you’ll need it later.
Note that what’s written in your template tag <orgTitle> will be displayed
in the dropdown list of available templates when user creates new metadata.
2 – Language specific tags : /web/loc/[lang]/xml/organisation.xml
Now, create the file “organisation.xml” that will be placed in
“[geonetwork_root_path]/web/loc/en/xml/”. This file will used to display
each metadata header and help information in different languages. So create
as many “organisation.xml” in the various localizations your geonetwork
interface is available in. Following the example above, it will look like
this:
*Note that the “help=” attribute is not always present. This is a personal
decision, since most of the fields are self explanatory. However, all fields
should be explained.
<root>
  <metadata help="root entity which defines metadata about the
organisation">Organisation's Metadata</metadata>
  <orgTitle help="The organisation's name">Organisation's name</orgTitle>
  <orgAcronym help="abbreviations that is formed using the initial letters of
words or word parts in a name.">Acronym</orgAcronym>
  <orgParentInstitution help="The institution above this organisation, if
applicable">Parent institution</orgParentInstitution>
  <orgDesc help="Description of the main goal of the
organisation">Description</orgDesc>
  <orgContactus>Contact us</orgContactus>
    <orgAddress>Address</orgAddress>
    <orgPOBox>P.O. Box</orgPOBox>
    <orgCity>City</orgCity>
    <orgPostalcode>Postal Code / Zip</orgPostalcode>
    <orgProvince>Province / State</orgProvince>
    <orgCountry>Country</orgCountry>
    <orgPhone>Phone</orgPhone>
    <orgFax>Fax</orgFax>
    <orgWebsite>Website http://</orgWebsite>
    <orgEmail>Email</orgEmail>
  <orgSuppInfo help="any other descriptive information about the
dataset">Supplemental Information</orgSuppInfo>
  <orgContactInfo help="person to contact">Contact name</orgContactInfo>
    <orgContactName>Name</orgContactName>
    <orgContactRole>Position</orgContactRole>
    <orgContactEmail>Email</orgContactEmail>
    <orgContactPhone>Phone and ext.</orgContactPhone>
  <mdFileID help="unique identifier for this metadata file">File
identifier</mdFileID>
</root>
***I strongly suggest to write the “help=” attribute right now. If you
don’t, you will most likely never do it.
3- XSD creation : /web/xml/shemas/organisation/shema.xsd
XSD stands for XML Schema Definition. You will now tell geonetwork how your
xml is organized. This is also where you will tell your geonetwork’s api
implementation if some element are optional, mandatory, unique or if
multiple instance of them car be created. For an exhaustive list of options,
visit : http://www.w3schools.com/schema/el_element.asp
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema&quot;
elementFormDefault="qualified">
  <!-- complex type declaration -->
  <xs:element name="metadata" type="metadata"/>
  <xs:complexType name="metadata">
    <xs:sequence>
      <xs:element ref="orgTitle"/>
      <xs:element ref="orgAcronym"/>
      <xs:element ref="orgParentInstitution"/>
      <xs:element ref="orgDesc"/>
      <xs:element ref="orgSuppInfo"/>
      <xs:element ref="orgContactus"/>
      <xs:element minOccurs="0" maxOccurs="unbounded" ref="orgContactInfo"
      <xs:element ref="mdFileID"/>
    </xs:sequence>
  </xs:complexType>
  <xs:element name="orgContactInfo" type="orgContactInfo" />
  <xs:complexType name="orgContactInfo">
    <xs:sequence>
      <xs:element ref="orgContactName"/>
      <xs:element ref="orgContactRole"/>
      <xs:element ref="orgContactEmail"/>
      <xs:element ref="orgContactPhone"/>
    </xs:sequence>
  </xs:complexType>
  <xs:element name="orgContactus" type="orgContactus"/>
  <xs:complexType name="orgContactus">
    <xs:sequence>
      <xs:element ref="orgAddress"/>
      <xs:element ref="orgPOBox"/>
      <xs:element ref="orgCity"/>
      <xs:element ref="orgPostalcode"/>
      <xs:element ref="orgProvince"/>
      <xs:element ref="orgCountry"/>
      <xs:element ref="orgPhone"/>
      <xs:element ref="orgFax"/>
      <xs:element ref="orgWebsite"/>
      <xs:element ref="orgEmail"/>
    </xs:sequence>
  </xs:complexType>
  <!-- ELEMENT DECLARATIONS -->
  <xs:element name="orgTitle" type="xs:string"/>
  <xs:element name="orgAcronym" type="xs:string"/>
  <xs:element name="orgDesc" type="xs:string"/>
  <xs:element name="orgParentInstitution" type="xs:string"/>
  <xs:element name="orgAddress" type="xs:string"/>
  <xs:element name="orgPOBox" type="xs:string"/>
  <xs:element name="orgCity" type="xs:string"/>
  <xs:element name="orgPostalcode" type="xs:string"/>
  <xs:element name="orgProvince" type="xs:string"/>
  <xs:element name="orgCountry" type="xs:string"/>
  <xs:element name="orgPhone" type="xs:string"/>
  <xs:element name="orgFax" type="xs:string"/>
  <xs:element name="orgWebsite" type="xs:string"/>
  <xs:element name="orgEmail" type="xs:string"/>
  <xs:element name="orgContactName" type="xs:string"/>
  <xs:element name="orgContactPhone" type="xs:string"/>
  <xs:element name="orgContactEmail" type="xs:string"/>
  <xs:element name="orgContactRole" type="xs:string"/>
  <xs:element name="orgSuppInfo" type="xs:string"/>
  <xs:element name="mdFileID" type="xs:string"/>
</xs:schema>
4- Geonetwork specific stylesheet files : /web/xml/schemas/organisation/…
Geonetwork’s api will need few xsl files in your schema’s folder in order to
perform various operations such as getting the uuid or the thumbnail. Here
is a very simple version of the each files needed. You can just copy paste
them. Perhaps, more complexes operations can be done. I suggest looking at
the fgdc-std or iso19115 files for complete examples.
extract-thumbnails.xsl
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform&quot;&gt;
  <xsl:template match="metadata">
    <thumbnail/>
  </xsl:template>
</xsl:stylesheet>
extract-uuid.xsl
  <xsl:template match="Metadata">
     <uuid><xsl:value-of select="mdFileID"/></uuid>
  </xsl:template>
</xsl:stylesheet>
shema-suggestions.xml
  this file seam to be there for informative purposes, leave-it blank
<fields>
<!-- <field name="">
    <suggest name=""/>
  </field>
</fields>
set-thumbnail.xsl
  <xsl:template match="/root">
     <xsl:apply-templates select="metadata"/>
  </xsl:template>
  <xsl:template match="@*|node()">
     <xsl:copy>
        <xsl:apply-templates select="@*|node()"/>
     </xsl:copy>
  </xsl:template>
</xsl:stylesheet>
unset_tumbnail.xsl
  </xsl:template>
    <xsl:copy>
    </xsl:copy>
  </xsl:template>
</xsl:stylesheet>
update-fixed-info.xsl
  </xsl:template>
     <xsl:copy>
     </xsl:copy>
  </xsl:template>
</xsl:stylesheet>
5- Geonetwork’s searching stylesheet : /web/xml/search/organisation.xsl
By default, Geonetwork’s search engine will search the “title”, “abstract”,
“keywords” and “geographic box”. So you need to match at least one of those
with your metadata schema. In our organisation example, there is no coverage
region or keywords, but you can look at the other templates.
<?xml version="1.0" encoding="UTF-8" ?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform&quot;
version="1.0">
<xsl:template match="/">
  <Document>
    <xsl:apply-templates select="/metadata/orgTitle">
      <xsl:with-param name="name" select="'title'"/>
      <xsl:with-param name="token" select="'true'"/>
    </xsl:apply-templates>
    <xsl:apply-templates select="/metadata/orgDesc">
      <xsl:with-param name="name" select="'abstract'"/>
    <Field name="any" store="false" index="true" token="true">
      <xsl:attribute name="string">
        <xsl:apply-templates select="/metadata" mode="allText"/>
      </xsl:attribute>
    </Field>
    <!-- locally searchable fields -->
    <!-- defaults to true -->
    <Field name="digital" string="true" store="false" index="true"
token="false"/>
  </Document>
</xsl:template>
<!-- text element, by default indexed, not stored nor tokenized -->
<xsl:template match="*">
  <xsl:param name="name" select="name(.)"/>
  <xsl:param name="store" select="'false'"/>
  <xsl:param name="index" select="'true'"/>
  <xsl:param name="token" select="'false'"/>
  <Field name="{$name}" string="{string(.)}" store="{$store}"
index="{$index}" token="{$token}"/>
</xsl:template>
<!-- codelist element, indexed, not stored nor tokenized -->
<xsl:template match="*[./*/@value]">
  <Field name="{$name}" string="{*/@value}" store="false" index="true"
token="false"/>
</xsl:template>
<!--allText -->
<xsl:template match="*" mode="allText">
  <xsl:for-each select="@*"><xsl:value-of select="concat(string(.),'
')"/></xsl:for-each>
  <xsl:choose>
    <xsl:when test="*"><xsl:apply-templates select="*"
mode="allText"/></xsl:when>
    <xsl:otherwise><xsl:value-of select="concat(string(.),'
')"/></xsl:otherwise>
  </xsl:choose>
</xsl:template>
</xsl:stylesheet>
6- Your own Schema’s Stylesheet : /web/xsl/metadata-organisation.xsl
This is the file you can end up playing with for days without knowing what
you’re doing… and… on top of that… expecting to have some results. I wish no
body will ever go through those days after me, this is why I’m writing this
document.
This is the stylesheet that will be used by geonetwork to show the content
of your metadata according to user’s request for viewing or editing it. In
both case, it is possible for the user to choose between the “simple”,
“advanced” or “xml” view. Depending on what the user is doing with the
metadata, we need to show it different ways. Note that there is no need for
any specification in the “xml” view, since we simply show the raw metadata
in it’s xml form.
  xmlns:geonet="http://www.fao.org/geonetwork&quot;&gt;
  default: in simple mode just a flat list
  <xsl:template mode="organisation" match="*|@*">
    <xsl:param name="schema"/>
    <xsl:param name="edit"/>
    <xsl:apply-templates mode="element" select=".">
      <xsl:with-param name="schema" select="$schema"/>
      <xsl:with-param name="edit" select="$edit"/>
      <xsl:with-param name="flat" select="$currTab='simple'"/>
  </xsl:template>
  these elements should be boxed
  <xsl:template mode="organisation" match="orgContactInfo|orgContactus">
    <xsl:apply-templates mode="complexElement" select=".">
  </xsl:template>
  make the following fields always not editable:
  mdFileID
  <xsl:template mode="organisation" match="mdFileID">
      <xsl:with-param name="edit" select="false()"/>
  </xsl:template>
  orgDesc, orgSuppInfo
  <xsl:template mode="organisation" match="orgDesc|orgSuppInfo">
    <xsl:apply-templates mode="simpleElement" select=".">
      <xsl:with-param name="text">
        <xsl:call-template name="getElementText">
          <xsl:with-param name="rows" select="5"/>
        </xsl:call-template>
      </xsl:with-param>
  </xsl:template>
  <!-- organisation brief formatting -->
  <!-- this formating is used to show search results -->
  <xsl:template name="organisationBrief">
    <metadata>
      <title><xsl:value-of select="orgTitle"/></title>
      <abstract><xsl:value-of select="orgDesc"/></abstract>
      <xsl:copy-of select="geonet:info"/>
    </metadata>
  </xsl:template>
</xsl:stylesheet>
7- Modifying of geonetwork’s config files.
/web/WEB-INF/config.xml
Add this line into the <gui> section :
<xml name="organisation" file="xml/organisation.xml" />
/web/xsl/metadata-edit.xsl
if you want your metadata schema to have a thumbnail, add a line like this
into the “edit button” template section (<xsl:template name="editButtons"
  <!-- thumbnails -->
  <xsl:if test="string(geonet:info/schema)='organisation'">
    &#160;
    <button class="content"
onclick="doAction('{/root/gui/locService}/metadata.thumbnail.form')">
      <xsl:value-of select="/root/gui/strings/thumbnails"/>
    </button>
  </xsl:if>
/web/xsl/metadata-utils.xsl
Add this line at the top :
<xsl:include href="metadata-organisation.xsl"/>
and this line into the <!-- brief --> section:
<!-- organisation -->
<xsl:when test="$schema='organisation'">
  <xsl:call-template name="organisationBrief"/>
</xsl:when>
/web/xsl/metadata.xsl
Add these lines into the <!-- main schema switch -->
  <xsl:apply-templates mode="organisation" select="." >
</xsl:when>
8 – Database integration (I’m using SQLYog)
A) metadata table
Add organisation_template.xml to your table.
Make sure the id is unique
shemaid must be your schema’s name “organisation”
isTemplate must be set to “y”
data must be an exact copy of organisation_template.xml (see section “1 –
General structure“). If you worry about the tabs and carriage returns, just
delete them.
uuid, you can have your own generated by the International Telecommunication
Union at :
SQL statement example:
insert into `metadata`
(`id`,`schemaId`,`isTemplate`,`createDate`,`lastChangeDate`,`data`,`source`,`sourceUri`,`uuid`)
values ( '30', 'organisation' ,'y', '2007-06-21T15:21:47',
'2007-06-21T15:21:47' ,'<metadata><orgTitle>New
organisation</orgTitle><orgAcronym/><orgParentInstitution/><orgDesc/><orgSuppInfo/><orgContactus><orgAddress/><orgPOBox/><orgCity/><orgPostalcode/><orgProvince/><orgCountry/><orgPhone/><orgFax/><orgWebsite/><orgEmail/></orgContactus>
<orgContactInfo><orgContactName/><orgContactRole/><orgContactEmail/><orgContactPhone/>
</orgContactInfo>
<mdFileID>d5750700-1da8-11dc-95c5-0002a5d5c51b</mdFileID></metadata>','myGeoNet',NULL,'')
B) operationallowed table
The default groupId to give access to is “2”
The metadataId is 30 (see above)
The operationId is by default 0,1,2,4,5,6
(Do I need to specify to make one entry per operationId?)
9 – Testing
Connect to your geonetwork, choose your new schema, and create a new
metadata!
Jeroen Ticheler-3 wrote:
Hi Alejandro,
Hope this helps,
Ciao,
Jeroen
Hi.
template.
Thanks in advance.
Alejandro Dobarro.
discussions,
projects/geonetwork
View this message in context: http://www.nabble.com/Create-templates-tf3229937s18419.html#a11307457
Sent from the geonetwork-devel mailing list archive at Nabble.com.
