[GeoNetwork-devel] Created metadata by an editor can't be edited by other editor in same group
Hi
Seem in master (and most probably in 2.10), if an editor creates a metadata in group g1, the metadata gets only permissions for View and Notify.
This means that no other editor in the same group can edit it, a bit annoying I think.
Is there any good reason for this change? Can be changed in any config parameter to work like in previous versions. And if so, why this is not the default value?
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hola Jose,
2013/5/20 Jose Garcia <jose.garcia@anonymised.com>:
Hi
annoying I think.
I think it's not a bad idea to not to have too much permissions when
you start creating a record - the author is the only concerned at the
beginning.
And then he could add more permissions for review, validate the record ...
default value?
I'm not sure when/why the change occurs.
Cheers.
Francois
Thanks and regards,
Jose García
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
GeoNetwork-devel mailing list
