I have imported a FGDC XML metadata record through GeoNetwork's (2.4) Metadata Insert form with the "Generate UUID for inserted metadata" option.
However, sending a CSW GetRecords request (see below) does not include the <dc:identifier> with the generated UUID. This means that there is no way to get the a GetRecordsById transaction request to work and effectively makes the FGDC record useless to CSW clients that rely on GetRecordsById.
Is this a bug, a missing feature, or is there some rationale behind having GetRecordsResponse without the UUID?
Ciao, Wolfgang
CSW service: http://catalog.usgin.org/geonetwork/geonetwork/srv/en/csw
See the <dc:title>Colored Shaded Relief Map of the Great Basin</dc:title> record returned in the response of:
<?xml version="1.0"?>
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:gmd="http://www.isotc211.org/2005/gmd" service="CSW" version="2.0.2" resultType="results">
<csw:Query typeNames="csw:Record">
<csw:ElementSetName>full</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">
<PropertyIsLike wildCard="%" singleChar="_" escapeChar="\">
<PropertyName>AnyText</PropertyName>
<Literal>%relief%</Literal>
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
_______________________________
Wolfgang Grunberg
Arizona Geological Survey
wgrunberg@anonymised.com
520-770-3500
Thanks Francois!
The bug is fixed in the repository. <dc:identifier> with UUIDs are returned for FGDC metadata records that have been imported with and without the "Generate UUID for inserted metadata" option.
Ciao, Wolfgang
Wolfgang Grunberg
520-770-3500
On 2/11/2010 01:08, Francois Prunayre wrote:
Hello Wolfgang
2010/2/10 Wolfgang Grunberg<wgrunberg@anonymised.com>:
the<dc:identifier> with the generated UUID. This means that there is no
GetRecordsById.
See discussion with Archie [1] and the patch [2]. Maybe there's other
issue with the Generate UUID option ?
Ciao.
Francois
[1] http://n2.nabble.com/fgdc-metadata-identifier-in-CSW-response-td4057309.html#a4058660
[2] http://n2.nabble.com/SF-net-SVN-geonetwork-5556-trunk-web-geonetwork-xml-csw-schemas-fgdc-std-td4098286.html#a4098286
Ciao, Wolfgang
See the<dc:title>Colored Shaded Relief Map of the Great
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Wolfgang Grunberg
520-770-3500
SOLARIS 10 is the OS for Data Centers - provides features such as DTrace,
Predictive Self Healing and Award Winning ZFS. Get Solaris 10 NOW
http://p.sf.net/sfu/solaris-dev2dev
GeoNetwork-devel mailing list
