Hello everybody,
if you trying to insert a dataset which already exists you'll get the
following exception (via CSW-T):
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Cannot process transaction: FEHLER: doppelter
Schlüsselwert verletzt Unique-Constraint
»metadata_uuid_key«</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Possible solution?! (like trying to delete a dataset which does not
exists (via CSW-T)).
<csw:TransactionResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2">
<csw:TransactionSummary>
<csw:totalInserted>0</csw:totalInserted>
<csw:totalUpdated>0</csw:totalUpdated>
<csw:totalDeleted>0</csw:totalDeleted>
</csw:TransactionSummary>
</csw:TransactionResponse>
Just <csw:totalInserted>0</csw:totalInserted> in case of
<csw:totalInserted>1</csw:totalInserted>.
Kind regards
Juergen
