[GeoNetwork-devel] current nightly build does not work with ie7
Currently if I do a default install and attempt to access the web site using
IE7 the page displays
   GeoNetwork opensource catalogue
   Loading ...
There is a JavaScript error with the following.
   line: 366
   Char: 7
   Error: Object doesn't support this property or method
   Code:0
When I view the source I see the following for line 365 and 366
  Ext.onReady(function(){
                $("loading").hide();
We have a nightly build that was built just prior to the release of 2.8RC0
and it is working correctly.
I have tested todays trunk(master) and 2.8 nightly builds and the bug seems
to be there.
Anyone know of any commits done recently that would cause this error?
I rarely use IE otherwise I would have noticed the error sooner.
View this message in context: http://osgeo-org.1560.n6.nabble.com/current-nightly-build-does-not-work-with-ie7-tp4989131.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi GeoNetwork developers,
I can confirm the behaviour that has been described by Ian Wallen. Setting <meta http-equiv="X-UA-Compatible" content="IE=8"/> in the HTML header, as it was proposed in http://osgeo-org.1560.n6.nabble.com/GeoNetwork-2-6-4-main-home-display-problems-with-IE6-IE7-and-IE9-td3860323.html, will not help.
I would appreciate if this bug can be fixed.
Kind regards,
Jürgen Seib
Dr. Jürgen Seib
Deutscher Wetterdienst
TI1/K - IT-Koordination
Frankfurter Strasse 135
63067 Offenbach
Tel.: +49(69)8062-2609
EMail: juergen.seib@anonymised.com
Von: ianwallen [mailto:ianwallen@anonymised.com]
Gesendet: Mittwoch, 18. Juli 2012 18:54
An: geonetwork-devel@lists.sourceforge.net
Betreff: [GeoNetwork-devel] current nightly build does not work with ie7
   Loading ...
   line: 366
   Char: 7
   Code:0
We have a nightly build that was built just prior to the release of 2.8RC0 and it is working correctly.
I have tested todays trunk(master) and 2.8 nightly builds and the bug seems to be there.
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and threat landscape has changed and how IT managers can respond. Discussions will include endpoint security, mobile security and the latest in malware threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
I have created ticket http://trac.osgeo.org/geonetwork/ticket/996 996 for
this issues. And I also found a fix although it seems odd.
I need others to test the patch to see if it breaks anything else on other
browsers.... I have tested with IE 7, IE8 and Latest Firefox and there does
not seem to be any issues.
View this message in context: http://osgeo-org.1560.n6.nabble.com/current-nightly-build-does-not-work-with-ie7-tp4989131p4990811.html
