[GeoNetwork-devel] Custom formatting proposal vote
Today in the IRC meeting we discussed my new CustomFormatting proposal: http://trac.osgeo.org/geonetwork/wiki/CustomFormatting
So I would like to put it up for vote. We are branching for 2.8 next week so I would like to commit the feature this week.
Jesse
Hi Jesse,
I quite like the proposal.
We harvest metadata from around Australia and New Zealand. Only
yesterday a potential node manager stated that he would like to have
their own presentation format of their metadata. You proposal seems like
it would allow that.
However, maybe I missed something but I didn't see anything to indicate
that the URL or remote XSL could be applied to the metadata during the
harvesting process. Is that already covered by the application of an
XSL during the harvesting configuration or will that also need to be
added to the harvesting configuration interface?
Thanks.
John Hockaday
Jesse
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
The way we use it is that the data is all the same format in the database and one can view it using the formatters. Because of that I never looked at the harvesters issue. One thing I was considering is integrate these with the csw output formats. This would allow csw harvesting.
I wouldn’t imagine it would be too difficult to modify the harvester to harvest using the formatter service instead of or in addition to the service used currently.
Jesse
On Wed, May 2, 2012 at 1:38 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi Jesse,
However, maybe I missed something but I didn’t see anything to indicate
Thanks.
John Hockaday
Jesse
Exclusive live event will cover all the ways today’s security and
This could be used in harvester protocols that support requesting formats other than xml (eg Z3950 protocol). You could request html and xml - index the content from the xml, then present using the harvested html format. That way the custodian of the metadata could control the presentation and the indexed content of harvested records if an html bundle exists that can produce output for that schema.
I suppose that brings me to a question about the formatters proposal (which I like) - I understand that a formatter could handle records from a number of different schemas (this is good) but if I can get a list of formatters available on a GeoNetwork catalog from the metadata.formatter.list service (in order to request that a record/records be formatted with that formatter), how do I know which metadata schemas a particular formatter can be applied to? (I suspect I would just get nothing back from the formatter if the schema was not supported by it but this is a bit indirect).
Simon
Sent: Wednesday, 2 May 2012 4:13 PM
To: john.hockaday
Cc: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Custom formatting proposal vote
I wouldn't imagine it would be too difficult to modify the harvester to harvest using the formatter service instead of or in addition to the service used currently.
Jesse
On Wed, May 2, 2012 at 1:38 AM, john.hockaday <john.hockaday@anonymised.com<mailto:john.hockaday@anonymised.com>> wrote:
Hi Jesse,
Thanks.
John Hockaday
proposal: CustomFormatting – GeoNetwork opensource Developer website
Jesse
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comourceforge.net> geonetwork-devel List Signup and Options GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
At the moment you don’t know which schemas the sheet can be applied to. There is currently a config file in the formatter bundle which could easily contain a property that can specify the supported schemas. Shall I add that change?
I could probably get that change done today. I would also change the list service to have a parameter where one could specify the schema of interest or a metadata id and the list would get the bundles that work for that schema or metadata.
Jesse
Simon
To: john.hockaday
Jesse
On Wed, May 2, 2012 at 1:38 AM, john.hockaday <john.hockaday@anonymised.commailto:[john.hockaday@anonymised.com.](mailto:john.hockaday@anonymised.com)> wrote:
Hi Jesse,
Thanks.
John Hockaday
Jesse
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.netmailto:[GeoNetwork-devel@anonymised.comet](mailto:GeoNetwork-devel@lists.sourceforge.net) https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Jesse,
From my point of view it is a useful change - however I don't want to add anything extra to your workload before the feature freeze - so I don't think the change has to be committed as part of the proposal - it could be added as a small enhancement later (with a ticket as reminder) if you're busy with other things.
In short, I'm voting +1 for the proposal as is - it seems to me to provide a direct and useful way that sites can plug in their own presentations/formats for metadata records.
Simon
Sent: Wednesday, 2 May 2012 7:33 PM
To: Pigot, Simon (CMAR, Hobart)
Cc: john.hockaday@anonymised.com; geonetwork-devel@lists.sourceforge.net
At the moment you don't know which schemas the sheet can be applied to. There is currently a config file in the formatter bundle which could easily contain a property that can specify the supported schemas. Shall I add that change?
Jesse
On Wed, May 2, 2012 at 11:24 AM, <Simon.Pigot@anonymised.com<mailto:Simon.Pigot@…192…>> wrote:
Simon
From: Jesse Eichar [jesse.eichar@anonymised.com<mailto:jesse.eichar@anonymised.com>]
To: john.hockaday
Cc: Devel geonetwork-devel@lists.sourceforge.net<mailto:geonetwork-devel@anonymised.comsts.sourceforge.net>
Jesse
On Wed, May 2, 2012 at 1:38 AM, john.hockaday <john.hockaday@anonymised.com<mailto:john.hockaday@anonymised.com><mailto:john.hockaday@anonymised.com>> wrote:
Hi Jesse,
Thanks.
John Hockaday
Jesse
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comourceforge.net><mailto:GeoNetwork-devel@lists.sourceforge.net> geonetwork-devel List Signup and Options GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
+1 for me Jesse.
Francois
2012/5/1 Jesse Eichar <jesse.eichar@anonymised.com>:
Jesse
Hi Jesse,
I think you should add that change. The easier it is to apply the XSL
for HTML presentation during the harvesting process of a particular
agency/node the more that function is likely to be used. (Especially by
me. ;--) )
Thanks.
John Hockaday
Jesse
        Simon
        To: john.hockaday
        vote
        Jesse
        Hi Jesse,
        Only
        to have
        seems like
        indicate
        during the
        application of an
        to be
        Thanks.
        John Hockaday
        > Today in the IRC meeting we discussed my new
        CustomFormatting
        > proposal:
        > So I would like to put it up for vote. We are branching for
        2.8 next
        > week so I would like to commit the feature this week.
        > Jesse
        > Live Security Virtual Conference
        > Exclusive live event will cover all the ways today's
        security and
        > threat landscape has changed and how IT managers can
        > will include endpoint security, mobile security and the
        latest in malware
        > threats.
        GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@lists.sourceforge.net> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Hi John.
It looked like the proposal passed so I have committed it. Now if you would be so kind and create a ticket for harvesting + formatter I will take that ticket and fix it as soon as I can.
Priorities say I have to do the harvesting scheduling work first though.
Jesse
On Thu, May 3, 2012 at 6:40 AM, john.hockaday <john.hockaday@anonymised.com25…> wrote:
Hi Jesse,
me. ;–) )
Thanks.
John Hockaday
Jesse
Simon
To: john.hockaday
vote
Jesse
<john.hockaday@anonymised.commailto:[john.hockaday@anonymised.com](mailto:john.hockaday@...825...)> wrote:
Hi Jesse,
Only
to have
seems like
indicate
during the
application of an
to be
Thanks.
John Hockaday
CustomFormatting
proposal:
2.8 next
Jesse
security and
latest in malware
threats.
GeoNetwork-devel@lists.sourceforge.netmailto:[GeoNetwork-devel@anonymised.comsourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net) https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Hi Jesse, it's not exactly the same as formatter but at least using
GeoNetwork harvester, you can apply XSL filter [1] [2] (coming from
the process directory) when harvesting . Maybe this option could be
more generic ...
Francois
[1] http://trac.osgeo.org/geonetwork/ticket/645
[2] http://geonetwork-opensource.org/manuals/trunk/eng/users/admin/harvesting/index.html#adding-a-geonetwork-node
2012/5/3 Jesse Eichar <jesse.eichar@anonymised.com>:
Hi John.
Jesse
On Thu, May 3, 2012 at 6:40 AM, john.hockaday <john.hockaday@anonymised.com>
wrote:
Hi Jesse,
me. ;--) )
Thanks.
John Hockaday
> Jesse
> Cheers,
> Simon
> From: Jesse Eichar [jesse.eichar@anonymised.com]
> To: john.hockaday
> vote
> Jesse
> <john.hockaday@anonymised.com<mailto:john.hockaday@anonymised.com.>>
> wrote:
> Hi Jesse,
> Only
> to have
> seems like
> indicate
> during the
> application of an
> to be
> Thanks.
> John Hockaday
> CustomFormatting
> > proposal:
> 2.8 next
> > Jesse
> security and
> latest in malware
> > threats.
