[GeoNetwork-devel] Custom GUI
Hi all!
I've been having a look around GeoNetwork and I found it to be a very interesting project. Still, I don't really like the GUI and I'd like to develop my own to attach it to the rest of GeoNetwork's backend. I have no doubt this is feasible, but I am a bit lost. I guess I'll have to send data to the server side via AJAX with the data in the XML format defined for the different XML services, right? Still, I'm a bit lost too with all the config-*.xml files which seem to define quite a lot of things and Im not sure if or how i should change them.
Thanks for your time!! :slight_smile:
Mikel Gonzalez Gainza,
Software garatzaile bekaduna CENER-en // Becario desarrollador de software en CENER
www.cener.com
This is a bigger question than you might realize. There are at the moment 3 Geonetwork UIs and some of which are extremely configurable. For your information I have some links below so you can take a look. The most flexible UI is the Widget UI so I will start with those examples:
Widget UI examples:
http://newgui.geocat.net/geonetwork/apps/tabsearch/
http://newgui.geocat.net/geonetwork/apps/search/
( I used to have many more examples but seem to have misplaced them :frowning: )
Main UI example:
http://newgui.geocat.net/geonetwork/srv/eng/main.home
The widget UI is flexible because it is composed of many different javascript objects and therefore can be combined in many different ways and with different CSS
Jesse
On Wed, Dec 19, 2012 at 12:43 PM, Mikel Gonzalez Gainza <mgonzalez@anonymised.com> wrote:
Hi all!
I’ve been having a look around GeoNetwork and I found it to be a very interesting project. Still, I don’t really like the GUI and I’d like to develop my own to attach it to the rest of GeoNetwork’s backend. I have no doubt this is feasible, but I am a bit lost. I guess I’ll have to send data to the server side via AJAX with the data in the XML format defined for the different XML services, right? Still, I’m a bit lost too with all the config-*.xml files which seem to define quite a lot of things and Im not sure if or how i should change them.
www.cener.com
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
GeoNetwork-devel mailing list
Hi, some more widget examples are in the proposal page here
http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui
Cheers.
Francois
2012/12/19 Jesse Eichar <jesse.eichar@anonymised.com>
Widget UI examples:
Main UI example:
Jesse
Hi all!
www.cener.com
Thanks both for the fast replies. I've been having a look at this Widget UI and it might actually do the trick! Although it seems that it's not included in the default .war. I built it from web-client module and got a .jar ... but, it's only js?? Anyways, should I put his jar inside WEB-INF/lib? I understand that I'll also need to add something either in config.xml or config-gui.xml, right?
thanks for your help again :slight_smile:
www.cener.com
________________________________________
Hemendik: Francois Prunayre [fx.prunayre@anonymised.com]
Bidaltze-data: asteazkena, 2012.eko abenduak 19 13:48
Nori: Jesse Eichar
Cc: Mikel Gonzalez Gainza; geonetwork-devel@lists.sourceforge.net
Gaia: Re: [GeoNetwork-devel] Custom GUI
Cheers.
Francois
2012/12/19 Jesse Eichar <jesse.eichar@anonymised.com<mailto:jesse.eichar@anonymised.com…>>
Widget UI examples:
Main UI example:
Jesse
On Wed, Dec 19, 2012 at 12:43 PM, Mikel Gonzalez Gainza <mgonzalez@anonymised.com.<mailto:mgonzalez@anonymised.com>> wrote:
Hi all!
www.cener.com<http://www.cener.com>
GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comforge.net>
If you want to do a quick test I suggest that you download a nightly build
from
Latest 2.8 branch (soon to be released)
http://nightlybuild.geonetwork-opensource.org/28branch/
i.e. geonetwork-install-trunk-2012-12-18.jar
Then install the software using the following command
java -jar geonetwork-install-trunk-2012-12-18.jar
During the installation choose the option to use the new tab interface.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Custom-GUI-tp5023893p5023942.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
If you are building from source you need to build with one of the widget profiles to get the javascript. for example:
mvn install -Pwidgets
That will do 2 things.
  1. make the default home page be geonetwork/apps/search
  2. make include all the js in web-client in the war.
Jesse
On Wed, Dec 19, 2012 at 4:06 PM, Mikel Gonzalez Gainza <mgonzalez@anonymised.com> wrote:
Thanks both for the fast replies. I’ve been having a look at this Widget UI and it might actually do the trick! Although it seems that it’s not included in the default .war. I built it from web-client module and got a .jar … but, it’s only js?? Anyways, should I put his jar inside WEB-INF/lib? I understand that I’ll also need to add something either in config.xml or config-gui.xml, right?
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
2012/12/19 Jesse Eichar <jesse.eichar@anonymised.commailto:[jesse.eichar@anonymised.com](mailto:jesse.eichar@anonymised.com...)>
Widget UI examples:
Main UI example:
Jesse
On Wed, Dec 19, 2012 at 12:43 PM, Mikel Gonzalez Gainza <mgonzalez@anonymised.commailto:[mgonzalez@anonymised.com](mailto:mgonzalez@anonymised.com)> wrote:
Hi all!
GeoNetwork-devel@lists.sourceforge.netmailto:[GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net)
Hey,
I´m also experimenting with the widget-UI at the moment and I like the approach a lot. I have 2 questions regarding that:
  1. I´m developing within Eclipse and yet have mostly been customizing version 2.6.4 to our needs. With the new widget-UI, what is the exact workflow when I´ve performed only a minor change in one of the widget-based “apps”?
    First build the geonetwork-client-project and then? The reason why I´m asking is that I don´t wanna perform a complete build for geonetwork-main (including compiling etc. to achieve the changed apps being included. The way Jesse mentioned refers to a complete build of geonetwork as far as I see it, right?
  2. Is there any kind of guideline/documentation yet on how we could develop our own interface yet (e.g. describing the interfaces that could be used to the serverside)?
Best regards and thanks in advance
Max Stephan
Sent: 19 December 2012 16:41
To: Mikel Gonzalez Gainza
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Custom GUI
Jesse
On Wed, Dec 19, 2012 at 4:06 PM, Mikel Gonzalez Gainza <mgonzalez@…928…> wrote:
www.cener.com
Hemendik: Francois Prunayre [fx.prunayre@…31…]
Nori: Jesse Eichar
Cheers.
Francois
2012/12/19 Jesse Eichar <jesse.eichar@…189…mailto:[jesse.eichar@...189...](mailto:jesse.eichar@...189...)>
Widget UI examples:
Main UI example:
Jesse
On Wed, Dec 19, 2012 at 12:43 PM, Mikel Gonzalez Gainza <mgonzalez@…928…mailto:[mgonzalez@...928...](mailto:mgonzalez@...928...)> wrote:
Hi all!
Maven is setup to get the data files from the sources directory so if you run with maven and debug with eclipse via the debug remote application you can update the javascript files all you want and it will be instantly available. I think francois runs from eclipse but I can’t give advice on that.
If you use the widget ui you will want to load the /apps/search/index_debug.html file so you get the non-minified js files.
I have attached a couple of scripts that I use for starting jetty on the commandline. You will need a linux console to run them or customize them for windows shell.
If first do a full build from the root directory and the put the 2 script files into web and cd web and execute them from there.
Jesse
(attachments)
clean (62 Bytes)
mvn_run_jeichar.sh (627 Bytes)
On Thu, Dec 20, 2012 at 4:01 PM, Max Stephan <max.stephan@anonymised.com> wrote:
Hey,
Max Stephan
From: Jesse Eichar [mailto:jesse.eichar@anonymised.com]
Jesse
www.cener.com
Nori: Jesse Eichar
Cc: Mikel Gonzalez Gainza; geonetwork-devel@anonymised.comurceforge.net
Cheers.
Francois
2012/12/19 Jesse Eichar <jesse.eichar@anonymised.commailto:[jesse.eichar@anonymised.com](mailto:jesse.eichar@anonymised.com)>
Widget UI examples:
Main UI example:
Jesse
On Wed, Dec 19, 2012 at 12:43 PM, Mikel Gonzalez Gainza <mgonzalez@anonymised.commailto:[mgonzalez@anonymised.com..](mailto:mgonzalez@anonymised.com)> wrote:
Hi all!
GeoNetwork-devel@anonymised.com.sourceforge.netmailto:[GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@anonymised.comrceforge.net)
2012/12/20 Jesse Eichar <jesse.eichar@anonymised.com>
available. I think francois runs from eclipse but I can't give advice on
that.
Running from eclipse is really like running from mvn jetty:run -Pwidgets.
And using the index_debug.html which points to the non-minified version is
the only point to take care of.
Francois
for windows shell.
Jesse
Hey,****
approach a lot. I have 2 questions regarding that:****
**1. **I´m developing within Eclipse and yet have mostly been
see it, right?****
**2. **Is there any kind of guideline/documentation yet on how we
could be used to the serverside)?****
Best regards and thanks in advance****
Max Stephan****
*From:* Jesse Eichar [mailto:jesse.eichar@anonymised.com]
*Sent:* 19 December 2012 16:41
*To:* Mikel Gonzalez Gainza
*Cc:* geonetwork-devel@lists.sourceforge.net
*Subject:* Re: [GeoNetwork-devel] Custom GUI****
profiles to get the javascript. for example:****
mvn install -Pwidgets****
That will do 2 things. ****
1. make the default home page be geonetwork/apps/search****
2. make include all the js in web-client in the war.****
Jesse****
mgonzalez@anonymised.com> wrote:****
thanks for your help again :-)****
software en CENER
www.cener.com****
Nori: Jesse Eichar
Gaia: Re: [GeoNetwork-devel] Custom GUI****
Cheers.
Francois
jesse.eichar@anonymised.com>>****
Widget UI examples:
Main UI example:
with different CSS
Jesse
mgonzalez@anonymised.com<mailto:mgonzalez@anonymised.com>> wrote:
Hi all!
software en CENER****
www.cener.com<http://www.cener.com>****
GeoNetwork-devel mailing list****
GeoNetwork-devel@lists.sourceforge.net>****
http://sourceforge.net/projects/geonetwork****
Hey Jesse and Francois,
Thanks for your assistance.
I´m running Eclipse on a windows machine and test Geonetwork in tomcat through Eclipse (tomcat is registered as a server there). When I change something in the apps-javascripts it´s automatically reflected in the debug-versions of the apps. Logically those changes persist only as long as I don´t perform a clean or a new “mvn install”. Both of which delete or overwrite the changes.
So far this behavior is the same as if I would change something in the non-minified javascripts for the traditional UI in the target-folder. But in this case I could simply perform something like “mvn yuicompressor:compress” and afterwards, if the WAR-file is needed “mvn war:war” which avoids unnecessary recompilation and other avoidable steps executed for the install goal. That´s what I´m looking for right now.
I´m not that familiar with maven, so sorry if some of the questions are a bit noobish. What would be great is some similar behavior as with the javascripts of the traditional UI so that I can achieve the following:
  • Make some changes to the apps
  • Build and in this process minify them
  • Include them in the final build of geonetwork (with recompiling Java etc.)
Is that possible?
Best regards
Max Stephan
Sent: 20 December 2012 16:05
To: Max Stephan
Jesse
On Thu, Dec 20, 2012 at 4:01 PM, Max Stephan <max.stephan@…458…> wrote:
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
OK, found out for myself (and also saw my last bulletpoint is a bit weird … I meant to say “withOUT recompiling Java …”).
So, I´m just doing “mvn install” for geonetwork-client (don´t know if I could also trigger some “smaller” goal, but “mvn yuicompressor:compress” didn´t do the trick), then I perform “mvn war:war” for geonetwork-main which also copies the changes to the target-folder of geonetwork-main and I get what I wanted to achieve.
Best regards
Max Stephan
Sent: 20 December 2012 17:24
To: Jesse Eichar; Francois Prunayre
Is that possible?
Best regards
Max Stephan
To: Max Stephan
Jesse
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
What sources are you editing?
I will speak for my setup. As mentioned before I run jetty with maven.
That way the sources I edit are in the web-client/src/main/resources
folder. This way I never accidentally delete my changes without explicitly
rolling back with git.
To test the minified files I simply (leaving jetty running):
cd web-client
mvn prepare-package
There are no java sources in web-client so this is about as fast as can be
done. I often kill the process went the minification step is done because
I don't need the jar yet.
Jesse
On Thu, Dec 20, 2012 at 6:24 PM, Max Stephan <max.stephan@anonymised.com> wrote:
… I meant to say “withOUT recompiling Java …”).****
get what I wanted to achieve.****
Best regards****
Max Stephan****
*From:* Max Stephan [mailto:max.stephan@anonymised.com]
*Sent:* 20 December 2012 17:24
*To:* Jesse Eichar; Francois Prunayre
Hey Jesse and Francois,****
Thanks for your assistance.****
overwrite the changes.****
executed for the install goal. That´s what I´m looking for right now.****
javascripts of the traditional UI so that I can achieve the following:****
**- **Make some changes to the apps****
**- **Build and in this process minify them****
**- **Include them in the final build of geonetwork (with
recompiling Java etc.)****
Is that possible?****
Best regards****
Max Stephan****
*From:* Jesse Eichar [mailto:jesse.eichar@anonymised.com<jesse.eichar@anonymised.com.>]
*Sent:* 20 December 2012 16:05
*To:* Max Stephan
that.****
/apps/search/index_debug.html file so you get the non-minified js files.**
for windows shell.****
files into web and cd web and execute them from there.****
Jesse ****
On Thu, Dec 20, 2012 at 4:01 PM, Max Stephan <max.stephan@anonymised.com> wrote:*
Hey,****
see it, right?****
Max Stephan****
Jesse****
en CENER
www.cener.com****
Nori: Jesse Eichar
Cheers.
Francois****
Widget UI examples:
Main UI example:
with different CSS
Jesse****
Hi all!
en CENER****
I got back to testing the widget-interface now. I tried following the steps you did and geonetwork is running fine through jetty within Eclipse. The problem is though that the apps/widgets are not accessible (when I call localhost:8080/geonetwork/apps/ I get an 404-error).
Steps I performed:
  • “mvn install” for all projects
  • “mvn jetty:run” for geonetwork-main
  • “mvn prepare-package” for geonetwork-client
Any idea what I´m missing?
Best regards
Max Stephan
Sent: 21 December 2012 08:17
To: Max Stephan
Cc: Francois Prunayre; geonetwork-devel@lists.sourceforge.net
I will speak for my setup. As mentioned before I run jetty with maven. That way the sources I edit are in the web-client/src/main/resources folder. This way I never accidentally delete my changes without explicitly rolling back with git.
cd web-client
mvn prepare-package
There are no java sources in web-client so this is about as fast as can be done. I often kill the process went the minification step is done because I don’t need the jar yet.
Jesse
Best regards
Max Stephan
Is that possible?
Best regards
Max Stephan
To: Max Stephan
Jesse
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
localhost:8080/geonetwork/apps/search
or
localhost:8080/geonetwork/apps/tabsearch
usually the url you are looking for is either:
Yep, I know. None of these is working though. With localhost:8080/geonetwork/apps/ I got a list of “widget-interfaces” and examples running through tomcat, therefore I tried that with jetty as well. But with jetty I always get a 404-error.
Sent: 20 February 2013 14:08
To: Max Stephan
or
Hi Max
You need to use this instead:
$ mvn jetty:run -Penv-dev,widgets
Widgets require to specify the widgets maven profile. env-dev profile is recommended to develop to avoid caching of xslt files and be able to do changes in xslt without requiring restart.
Jose García
On Wed, Feb 20, 2013 at 1:47 PM, Max Stephan <max.stephan@anonymised.com> wrote:
Steps I performed:
Best regards
Max Stephan
To: Max Stephan
cd web-client
mvn prepare-package
Jesse
Best regards
Max Stephan
From: Max Stephan [mailto:max.stephan@anonymised.com]
Is that possible?
Best regards
Max Stephan
To: Max Stephan
Jesse
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks Jose, that was the solution. Didn´t know you had to apply that profile to the jetty:run-goal as well.
Sent: 20 February 2013 15:10
To: Max Stephan
Cc: Jesse Eichar; geonetwork-devel@lists.sourceforge.net
Hi Max
Jose García
On Wed, Feb 20, 2013 at 1:47 PM, Max Stephan <max.stephan@…458…> wrote:
Steps I performed:
Best regards
Max Stephan
To: Max Stephan
cd web-client
mvn prepare-package
Jesse
Best regards
Max Stephan
Is that possible?
Best regards
Max Stephan
To: Max Stephan
Jesse
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Max
Indeed I think the maven profiles available are not documented in the development manual. I’ll check to add a section about this.
Jose García
On Wed, Feb 20, 2013 at 4:17 PM, Max Stephan <max.stephan@anonymised.com> wrote:
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
To: Max Stephan
Hi Max
Jose García
Steps I performed:
Best regards
Max Stephan
To: Max Stephan
cd web-client
mvn prepare-package
Jesse
Best regards
Max Stephan
Is that possible?
Best regards
Max Stephan
To: Max Stephan
Jesse
Hey,
Max Stephan
Jesse
www.cener.com
Nori: Jesse Eichar
Cheers.
Francois
Widget UI examples:
Main UI example:
Jesse
Hi all!
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
