I am building a somewhat customised version of the gui widgets search
interface and am having difficulty manipulating the size of the discovery
map as was requested by a customer. I am basing this interface on the
apps/search/index_debug.html and the corresponding apps.js file. Can anyone
give me some pointers as to how to do this?
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/Customise-the-map-size-in-gui-widgets-interface-tp4559460p4559460.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Byron,
I guess you want to change the width param in viewport, ‘east’ region. (line 745)
If you change it after loading, you may have to make a viewport.doLayout() to update the layout.
Jean
2012/3/8 ByronCinNZ cochranes4@anonymised.com
Byron
Virtualization & Cloud Management Using Capacity Planning
Cloud computing makes use of virtualization - but cloud computing
also focuses on allowing computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
GeoNetwork-devel mailing list
