[GeoNetwork-devel] Customizing Opensearch
I want to be able to search against a Geonetwork catalog by using the Opensearch protocol.
I already read that Opensearch should be enabled by a file descriptor that is put on this path of the GN instance:
http:///geonetwork/srv/eng/portal.opensearch
An example of this document is here. It contains search templates.
  • How can i enable Opensearch?
  • How can i customize it?
  • I would also like to know if there’s any useful documentation on this matter.
