[GeoNetwork-devel] Data directory issues
Hi
I’m having issues to get copied the schemas to an external data directory. The folder is created during the startup for the metadata schemas, but it’s empty, no schema is copied there.
Checking the code in 2.10.3 (also similar code seem in develop branch). I can’t really understand if this really works.
In GeonetworkDataDirectory:
  • First is call setDataDirectory to define the folders for indexes, schemas, etc. This method creates the directories if doesn’t exist.
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/java/org/fao/geonet/GeonetworkDataDirectory.java#L321-L324
  • After that initDataDirectory is call and copies the information, but seem only if the destination directory doesn’t exist. But that folder has been created in previous step.
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/java/org/fao/geonet/GeonetworkDataDirectory.java#L261-L264
Not sure if I’m doing something wrong or this is really a bug? Any feedback is welcome.
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
