[GeoNetwork-devel] Database error when running the latest GN 2.7?
I am having problem with suspecious database issues.
I checked out the latest GN code from SVN and used Maven to compile and
build it. All worked OK.
And I deployed it on Tomcat 6.0. It was successfully deployed.
Then I go to "http://localhost:8080/geonetwork"\. It threw out the following
error on the screen.
http://osgeo-org.1803224.n2.nabble.com/file/n6926940/GN_Error_screenshot1.jpg
I am new to GN. Could anyone give me an idea please? Thanks!!!
Alex
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Database-error-when-running-the-latest-GN-2-7-tp6926940p6926940.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
The problem seems to be
/var/lib/tomcat6/geonetwork.lock.db, Permission denied
Enter:
ps -ef | grep java
to see which user is used for tomcat (first column).
I assume the user is "tomcat".
Enter:
groups tomcat
to see the groups of tomcat. I assume there is also a group named "tomcat".
Enter:
chown -R tomcat:tomcat /var/lib/tomcat6
Restart tomcat
Christian
Zitat von alextc <alex.tao.chen@anonymised.com>:
Then I go to "http://localhost:8080/geonetwork&quot;\. It threw out the following
Alex
The demand for IT networking professionals continues to grow, and the
demand for specialized networking skills is growing even more rapidly.
Take a complimentary Learning@anonymised.com Self-Assessment and learn
about Cisco certifications, training, and career opportunities.
http://p.sf.net/sfu/cisco-dev2dev
GeoNetwork-devel mailing list
This message was sent using IMP, the Internet Messaging Program.
Great! Your tips work as a charm!
Thanks so much for the help, Christian.
Now I have GN up and running but it seems Trunk hasn't got 2.7 merged in.
The Search Map is still with Interactive Map instead of OpenLayers on 2.7
Snapshot version.
Where can I check out GN 2.7 source code by the way?
Thanks!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Database-error-when-running-the-latest-GN-2-7-tp6926940p6927497.html
Fine
Snapshot version.
I am not a main developer, no idea, sorry.
svn co https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk <localdir>
Thanks!
Thanks Christian again for your prompt response!
Yes, I did check out the source code from this URL. The geonetwork.war was
built with Maven. All worked fine!
It's so weird that GN comes up with the old search map. But I found all the
ExtJS and OpenLayer library codes in the script folder. There may be
something in configuration that I missed out.
Thanks!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Database-error-when-running-the-latest-GN-2-7-tp6926940p6927566.html
Open a new thread on this topic, "Database error ..." is outdated.
I think you will get some information of a core developer soon.
Thanks!
