Hi
It seems the ‘month’ section of a selected date gets reset to ‘1’ in the following scenario:
- When rendering a Date & Time control for an empty DateTime element (or where only a date was assigned previously) and a date & time values is assigned and saved.
- This don’t happen once a time value was selected previously and saved. (When the edit mode is started with a time sect5ion already in the DateTime element, then the control behaves correctly)
I’m using GN 2.10.3 and ISO19139 templates
Any ideas/comments would be much appreciated.
Regards, Gert
