Dear PSC members,
I need a voting or decision about
http://trac.osgeo.org/geonetwork/ticket/394
adding DB2 Support. The attached patch is outdated and I want to know if it makes sense to create a new one.
If DB2 is not of public interest, I will do the necessary hacks for my customer and will not invest further, otherwise I will update the patch.
Thanks in advance.
Christian
This message was sent using IMP, the Internet Messaging Program.
Hi Christian
Not a PSC member, but for me seem good to support DB2.
If seem ok to PSC members about integrate DB2 support, I can manage about applying the patch in trunk when you create an updated patch.
Jose
On Wed, May 18, 2011 at 10:59 AM, <christian.mueller@anonymised.com> wrote:
Dear PSC members,
Thanks in advance.
Christian
What Every C/C++ and Fortran developer Should Know!
Read this article and learn how Intel has extended the reach of its
next-generation tools to help Windows* and Linux* C/C++ and Fortran
developers boost performance applications - including clusters.
http://p.sf.net/sfu/intel-dev2devmay
GeoNetwork-devel mailing list
2011/5/18 jose garcia <josegar74@anonymised.com>:
Hi Christian
Looks good to me. For the SQL script for data, I hope DB2 support the
default file we have (one file for all db in trunk). It will be easier
to maintain.
+1 for me Christian.
Francois
Jose
Dear PSC members,
Thanks in advance.
Christian
Thanks for your vote.
1) The sql script for data works for db2, no additional work here
2) For the sql script for the ddl , I always hat to change the following
a) use CLOB(1G) as datat type for very long text
b) comment lines start with --
c) attributes used as primary key must be declared "not null"
That is it.
3) Is the gast tool still supported ?
4) I see you document using sphinx (rst extension). I will add a patch for additional db2 documentation too.
Quoting Francois Prunayre <fx.prunayre@anonymised.com>:
Hi Christian
to maintain.
Francois
Jose
Dear PSC members,
Thanks in advance.
Christian
Thanks Christian,
Thanks for that patch! +1 also from me.
Ciao,
Jeroen
On 18 mei 2011, at 10:59, christian.mueller@anonymised.com wrote:
Dear PSC members,
#394 (Add DB2 for Unix/Windows support) – GeoNetwork opensource Developer website
Thanks in advance.
Christian
Looking here
http://trac.osgeo.org/geonetwork/wiki/PSC
I see that I need two +1 votes and none -1 vote.
+1 votes are from
Francois Prunayre
Jeroen Ticheler
Additionally, Jose offers to apply the patch on trunk
Since this is my first active contribution, I want to ask if it is ok to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
Thanks in advance.
Christian
Sorry for my late vote - +1 from me too.
Cheers and thanks,
Simon
________________________________________
From: christian.mueller@anonymised.com [christian.mueller@anonymised.com]
Sent: Monday, 23 May 2011 11:07 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] DB2 Support
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
Thanks in advance.
Christian
geonetwork-devel List Signup and Options
A late +1 from me too.
Ciao,
Emanuele
Alle 15:07:13 di lunedì 23 maggio 2011, christian.mueller@anonymised.com ha scritto:
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
> Thanks Christian,
> Ciao,
> Jeroen
>> Dear PSC members,
>> Thanks in advance.
>> Christian
>>------ What Every C/C++ and Fortran developer Should Know!
>> _______________________________________________
+1
from me as well.
Patrizia
-----Original Message-----
From: christian.mueller@anonymised.com [mailto:christian.mueller@anonymised.com]
Sent: 23 May 2011 15:07
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
patch.
Thanks in advance.
Christian
GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net
Short question. I need a place where I can describe how to prepare/configure the geonetwork/db2 combination.
Since I am an OSGeo user, I think I can edit
http://trac.osgeo.org/geonetwork/wiki/ListOfHowTos
Would this be the correct place. Users of Oracle have to download the jdbc jars also, but I found no documentation about this fact.
Christian
Quoting "Monteduro, Patrizia (NRL)" <Patrizia.Monteduro@anonymised.com>:
+1
from me as well.
Patrizia
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
patch.
Thanks in advance.
Christian
Hello Christian,
2011/5/31 <christian.mueller@anonymised.com>:
From my side, I think it's better to improve the user manual instead
of having lots of how-to.
We could add a chapter on setting up the database in
http://geonetwork-opensource.org/manuals/trunk/users/quickstartguide/installing/index.html#how-do-i-install-geonetwork-opensource
And you could add a patch for the doc.
What do you (and others) think ?
Cheers.
Francois
Christian
+1
from me as well.
Patrizia
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
patch.
Thanks in advance.
Christian
Simplify data backup and recovery for your virtual environment with vRanger.
Installation's a snap, and flexible recovery options mean your data is safe,
secure and there when you need it. Data protection magic?
Nope - It's vRanger. Get your free trial download today.
http://p.sf.net/sfu/quest-sfdev2dev
Hello Christian,
Cheers.
Yes, the manual is a better place. I will prepare a documentation patch describing how I handle the DB2 setup. Afterwards we can complete the chapter with information about other database systems.
Francois
Christian
+1
from me as well.
Patrizia
Looking here
+1 votes are from
Francois Prunayre
Jeroen Ticheler
to start now.
Christian
Thanks Christian,
Ciao,
Jeroen
Dear PSC members,
patch.
Thanks in advance.
Christian
Hi Jose, you find an updated patch
named db2.patch. Please make a short review and apply on trunk.
Thanks
Quoting jose garcia <josegar74@anonymised.com>:
Hi Christian
Jose
Dear PSC members,
Thanks in advance.
Christian
Hi Christian
Thanks for patch, I’ll check possibly tomorrow and apply in trunk.
Jose García
Thanks
Hi Christian
Jose
Dear PSC members,
Thanks in advance.
Christian
