In many of our debug logs we do things like:
Log.debug(Log.JEEVES, "message: "+Xml.getString(xml));
This can be very computationally expensive if xml is large. That is fine when in debug mode, unfortunately Xml.getString(xml) is done even when not in debug mode.
Sometime ago I added Log.isDebug(…) so a check can be made before doing an debug log. Last night I started a sweep through the code adding the guard to each debug statement.
Before doing more I wanted to make sure when I am done I can commit the work. (I will request a review when done).
Does anyone have any problems with this idea?
Jesse
Hi Jesse
For me seem a very good idea.
Jose García
On Thu, Apr 5, 2012 at 7:42 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jesse
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
I have made a ticket for this.
http://trac.osgeo.org/geonetwork/ticket/852
If I could get a quick review I would appreciate it. I think it is fairly low risk. No functional changes. I double checked that I got all the module names right.
jesse
Jesse
Great ! Just one comment : how about naming it isDebugEnabled() ? Then it’d look more like the normal logging libraries that all other software uses. It’ll be more easy to find for other developers.
Heikki
On Thu, Apr 5, 2012 at 8:58 AM, Jesse Eichar <jesse.eichar@anonymised.com…> wrote:
jesse
On Thu, Apr 5, 2012 at 7:42 AM, Jesse Eichar <jesse.eichar@anonymised.com…> wrote:
Jesse
Good suggestion. I will do that.
Heikki
On Thu, Apr 5, 2012 at 8:58 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
jesse
Jesse
