[GeoNetwork-devel] define multiple intranet parameters
Hello,
in order to implement the Geonetwork application at my company I would need to specify more that only one “network” and “netmask” parameters in order to define correctly the configuration of the intranet, because there is a complex configuration with many different offices. Does anybody know if there’s a way to get it?
Many thanks in advance. Regards,
Víctor
Víctor Centella Fuster
Prodevelop, Integración de tecnologías
http://www.prodevelop.es
Servei d’Informàtica
Conselleria de Medi Ambient, Aigua, Urbanisme i Habitatge
Francesc Cubells 7, 46011 València
Tel.: 96 197 3942
Email: asistenciagis1_ctv@anonymised.com
http://www.cma.gva.es
Hi
Victor Centella is asking to allow configure more than one network and
netmask in Geonetwork, but for now only 1 network and netmask is
allowed.
A quick fix should be modify isIntranet function in
org.fao.geonet.kernel.AccessManager class to process a comma-separated
list for network and netmask values.
Of course, the best way should be allow multiple input fields for values
in the config form.
Please give opinion about if this change it's interesting to incorporate
in trunk.
Jose García
El jue, 01-10-2009 a las 09:21 +0200, Víctor Centella Fuster escribió:
geonetwork-devel@lists.sourceforge.net
My opinion: better do it the best way, than using some quick-hack-dataformat that is bound to cause more troubles later on.
Kind regards
Heikki Doeleman
On Thu, Oct 1, 2009 at 12:44 PM, Jose Garcia <josegar74@anonymised.com> wrote:
Hi
allowed.
in the config form.
Please give opinion about if this change it’s interesting to incorporate
in trunk.
Jose García
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
GeoNetwork-devel mailing list
